Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Pritam,
If you have a look from when the AutoTune was performed Leonard can probably take a look.
https://drive.google.com/file/d/0B6OGol5wOFntSFBKanVkT0ljN1U/view?u...
It's RC7, and since 3.2.1 I have frequent EKF errors....
Is that because of the magnetometers differences (with Gyro/GPS) ?
Recently my copter's turned off motors while in stable at altitude 120m (no logs attached:().
Logs showed that there was EKF nav problem again (error 16 as I remember).
You've said that it's fixed in RC-6/7. I doubt then...
3CityDrones,
The problem is probably caused by very high vibrations. Below is the output of the VIBE message which shows the vibrations are up above 50m/s/s and clipping of the accelerometers is also happening. So not sure what vibration isolation system you're using but I'd recommend the 3M foam. Feel free to post a picture of how your flight controller is mounted.
Motors and props are perfectly balanced. FC is mounted by using thick 3m foam, exactly.
When FC replaced by naze32 , copter is flying briliant. Are you sure it's vibrations?
Please look at the magnetometer data... MagX for example. For me it could be caused by electromagnetic interferences - as problem is happening mainly in one place...
With rc7 copter is wobbling-in comparing to rc5. No autotune has been done since rc5.
3citydrones,
The VIBE message is pretty definitive about the amount of vibration. I'm not necessarily saying it's the only cause of the EKF-Check errors but the vibrations are very serious it would be best to resolve that issue first. The levels are about 3x what my IRIS produces and in the same range as the Evgeny logs in which the vehicle lost attitude control.
We are working on improved vibration resistance for -rc9 but in any case, these vibes are pretty serious and should be taken care of.
BTW, had another crash copter on 3.3-RC8. It's Pixhack too.
It's quad V-tail. Fly good in stab and Althold but after few minutes its made crazy and go to ground in angle ~45 rgad.
Log in attach. I think this because high vibration too.
Still wait for RC9
2015-08-03 17-47-11.bin
Yes, extremely, extremely high vibrations on that one.
Can you explain please? As I can see via IMU/IMU2 vibration is acceptable.
The IMU data is based on filtered accelerometer data, whereas the vibes are calculated on the raw IMU data.
Also your Acc data are (randomly; at least not related to pitch roll and yaw) increasing heavily. And since there is clipping you definitely have too high vibrations.
The best way is to look at all these data (IMU, Vibes and clipping) and to use the worst for interpretation.
Evgeny,
you should look at the Vibes messages (see: http://copter.ardupilot.com/wiki/common-measuring-vibration/ for more details).
As Rob mentioned the vibes are "extremely, extremely high" on your copter - they go up to 120. Normally it should be below 30. Below 50 should be ok. Depending on the damping system, the balancing of the props, and the frame setup it is possible to get the values below 10 even for larger copters (for in Loiter the vibes on one of my copters are < 5).
I suggest to change the damping system and to carefully balance the props/motors.
