Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • They are a bit of a pain to solder up but I really like how easily they disconnect.. Never had any problem with them.
              • I find them easy as long as you pre-tin just the hashed end of the gold tab and the wire you're using. If you go over that hashed area, or the wire gauge is too heavy then they just never go into the housing.
  • A testament 3.3 beta.  8 days of mapping at 7 to 8 hours a day.  Countless hours of flights without a glitch.  Pretty much all auto missions.  I'd say it's ready for release!  Lets get some lidar terrain following in 3.4beta now : )  Terrain data doesn't do me a lot of good when a mine site has change in the last 6 month lol!   So beyond the 3.4 wish list, awesome job on 3.3!
      Cool, thanks for the report!  We're planning on making Copter-3.3 the default version from the MP (and other GCSs) some time this week.
      • Congratulations to you and the Dev team! You did an amazing job.
    • +1!
  • Just had a very fun afternoon at a friend's farm with my 3DR X4 and QAV250, both running 3.3RC. I have taken advantage of IMU_USE to switch off my second dodgy IMU on my pixhawk and I have to say the results of that + 3.3RC + M8N are astounding. Absolutely rock solid. FPV was a delightful experience - I felt confident to go pretty much anywhere and everything worked 100% perfect. It was quite an eye-opener to compare the peformance of the M8N on the X4 with a 3DR LEA-6H on the QAV-250 - night and day in terms of stabilty, position holding etc. The QAV flew very well as well and was a lot of fun. Kudos to all concerned with the 3.3 development.
      Hi Andy,
      Good to hear people are starting to use arducopter on the 250's!! I am glad you are enjoying it!!
      • Hi Leonard - all thanks to you :)
        I'm interested in your COMPASS_MOT values. For the internal compass I have values of 50 on the X & Z access. Yes that's 50. Yours are much lower and yet this is the same frame. What could be generating so much interference? Could it really be the ESC's? I've carefully twisted all the motor wires, so I'm a bit perplexed.
        Even on the external I have values of around 5 for X & Z which still translates into something largish at 20 amps.
          Andy,
          I haven't seen your parameter file but I just wanted to check that you're not using the throttle based compassmot.  The throttle-based method (as opposed to the current based method) uses a different scale so the numbers appear much larger.  The thr method is also much less reliable because the compass interference is linear with current but not linear with throttle actually.  We're planning on removing the thr method for Copter-3.4.
