Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Emin, we will never stop advancing the code. If you don't like testing, then don't test the RC's and stick with the stable releases.
Pfffff...!
My thoughts exactly. Couldn't have said it better. I GREATLY appreciate all the efforts from the devs and testers!!! I don't want to criticize... But it would be nice to just fly without issues. I keep getting DCM bad heading in 3.2. I guess 3.3 fixed this but then it seems there's new issues? So I'm not sure what to do. It's not like I have a strange set up it's a standard quad gps and mag on a mast did compass mot 3 times, reinstalled FW, re-did calibrations.. Boy I have done all that a lot :[ It does fly great though. very smooth. poshold is excellent!! But my pulse rate goes up when I hear DCM bad heading then Landing!!! Not complaining though.. just saying ....
re- third compass +1 !!! I think my DCM bad heading would go away if I had the option to completely ignore the internal mag. Also it would be fantastic if there were two I2C ports so you don't need that splitter thus triples your wires and potential points of failure.
How much did we spend for the software we use? IMHO it is a small price to pay and part of the fun in the process. Along the way I have had more stable flights than not and almost every crash as been the result of operator error, either at the controls or the workbench. I find it staggering that we have the sophistication in product available to us. A big thanks to all the people that work to make this happen!
Cheers,
RB
I agree wholeheartedly. I’m just giving a little input to the process perhaps. I wonder if this would make sense…. when 3.3 came out it fixed a couple issues with 3.2. So maybe it would be wise to go add those patches to 3.2 and then add a note to that thread advising people to update 3.2 again. This way there is always a ‘stable’ release that is being made even better while at the same time working on the next beta. Know what I mean? It seems now the only way to address some issues with 3.2 is to go to 3.3 beta. But then there might be new issues. I don’t know maybe that already happens to some extent and I don’t even know about it. I have a LOT of enjoyment with this and it is utterly amazing when you think about how all this actually works at all!!! It’s come a long way since my first .049 ‘U’ control!! lol
I don't know, I have been following this tread from the beginning and people are having issues I haven't seen. I had a couple of problems with altitude and UAVCAN in the first 3.3rc but that is all fixed and I have had no issues on two quads and a medium sized hex. For general flights I trust 3.3 completely but have not tested the new features that are having issues(Flow, landing gear etc.). I even uploaded 3.4 Dev. on my quad this morning, did an autotune and it flew remarkably well. I think these guys are very close to completely stable firmware, especially since the hardware is far from perfect and prone to multiple problems with layout and construction. If you get GPS noise or glitches in your car nav or smartphone you don't even know, with these things you definitely find out. All in all this is a great experience and a great positive community.
Cheers,
RB
I updated to 3.3. It advises me I need to re-do the accell calibration as expected. I try to do this with APM2 and it won't work. It times out even though I clicked okay. It just won't move on and let me calibrate. I now get multiple weird warnings on my Taranis saying it's armed even though it isn't. It says it's flipping between multiple modes continuously. hmm is this related to Notes 2 above? who knows. I now have different new problems. Probably an APM2 issue?? Very frustrating even though it is free. I'll go back to 3.2 and live with the DCM bad heading for now I guess.
Your taranis issues are down to teensy/lua code that is known to be buggy on 3.3 and has nothing to do with the core apm project. It's a shortcoming in the teensy code. apmplanner2 is also not working fully properly with 3.3 yet - the latest master mostly works fine but still has a few small issues. They both work just fine with stable 3.2 code.
Worth noting that previously the devs did do stable point releases to fix bugs while releasing beta versions of the next branch (eg 3.1.4/3.1.5), I guess in this case though the changes to 3.3 are so extensive and time consuming their focus is just to get it stable and out the door. There are probably a lot of fixes that just can't be backported to 3.2.
Richard, you installed AC 3.3 rc5 on APM 2?
I was thinking that the highest compatible version of AC for APM 2.x is AC 3.2.1
