Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        Evgency,
        Yes, you're right.  Thanks for the self diagnosis.  We can see that the vibration levels are quite often in the 50m/s/s range (i.e. 5G) with peaks up to 80ms/s/s (8G).  That's perhaps 4x those of my IRIS.  There's also clipping happening and it starts at the moment the EKF Check goes off.
        This data is quite helpful in that it gives us an upper bound where we know problems start happening.
        3702711450?profile=original
        • I don't understand how it happens, that two accels placed on the same board have such different vibrations.
          And I have one more question. The same copter flies on AC3.2.1 perfectly, as I understand EKF instead of correcting a non-conformity of sensors, it strengthens them and makes flight impossible.
            Evgeny,
            We can't explain why one shows more clipping than the other I'm afraid but it could be some kind of physical effect of board flexing maybe.
            This log is making us re-think whether the solution we put in place after your previous crash did any good.  That solution was to de-weight the accels that are clipping but in this case things started going wrong even before they began clipping.
            What's unusual about the vibration it is in the horizontal direction.  Normally the vibrations are in the vertical direction presumably caused by the motors and propellers but in this case, it's in the horizontal direction which makes us wonder if something is bumping against the flight controller.
            Some questions:
            1. you don't remember which direction the vehicle leaned in do you?  We have two attitude solutions running and they disagree so it's hard for us to be sure which one to believe.  You helping us break the tie would be good.
            2. Is this a 3DR pixhawk or another manufacturer's board?  We don't mind the source of course but it removes some variables if we know.
            3. how is the flight controller mounted?  Can you provide a picture?
            4. if you have a log of this copter flying AC3.2.1 that'd be cool.
            • Thanks for support. Answers:
              1. Lean to left side, you can see MP log in attach (fly from 70% of length of log)
              2. It is Pixhack. It have anti-vibration plate inside with sensors.
              3. It is on double-sided adhesive tape and attached by buckle (see photo below).
              4. I try to fly today or tomorrow.
              P.S. You write: "That solution was to de-weight the accels that are clipping but in this case things started going wrong even before they began clipping."
              I not very good speak English (as you can see), can you explain what mean "clipping" in this case? It is mean sharp?
              2015-07-27 18-28-58.tlog
                Evgeny, Jesus, Paul, Artem,
                Well, I wouldn't have expected that!  I've heard of the PixHack but did not know it had built in anti-vibration isolated IMU.  It seems like a good idea but in this case at least it's performance is not good.  I'd recommend going back to the more traditional 3M vibration dampening foam.
                Evgeny, we don't actually have a lot of vehicles with this level of vibration.  I was wondering if you could leave it in it's current configuration and test -rc9 when it's out in about a week (or maybe a little less)?  We're going to try one more idea to improve vibration resistance.  After that testing is done, I'd recommend using the 3M foam or something similar.
                • Ok, I leave this frame for testing RC9. And now I assembling new frame same as previous but with anti-vibration platform and try to check in with AC3.3
                  Thanks for support.
              • Those pixhack have been famous AFAIK for their problem with vibration
                https://storage.ning.com/topology/rest/1.0/file/get/3702908516?profile=original
                • Yes, the original CUAV pixhack has aluminum shell and the silicon padding inside was specifically designed to dampen high frequency vibes. The plastic case version appears to be not made as good as the aluminum and the silicon pad is harder and is of the different shape.
                  I have used the original CUAV pixhack for one of my clients. It is indeed a quality made piece of hardware with great IMU dampening especially effective against high frequency vibes. After a positive experience with the "real" thing I have erroneously purchased one in a plastic case (didn't pay enough attention) that one went right back to the seller for a full refund.
                • Yes, it have anti-vibrations palte with sensor, so I can mount it hard on copter and have good level of vibration. But I'm not sure about second IMU unit, it show high level of vibration.
                  • My bad Eugene, I must be going blind or something, as on the last picture it sure looks to me as plastic case :D. And yes, as a decent gimbal for anything g bigger than a GOPRO costs about $2k AC 3.3's support of storm32 makes it very attractive.
