Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Try autotrim. Also, do you do acc calibration via telemetry or via usb cable? If you do via USB cable it can pull the board towards itself resulting in imperfect level calibrations. I do all my calibrarions via telemetry these days even if I am not using it while flying.
I will try auto trim. The tricopter I had a similar issue with seemed not to drift in Stabilize, but would in Alt Hold. But this guy seems to drift similarly in Stabilize, foward and to the right. I, too learned my lesson on calibration via telemetry vs. cable... especially doing so on a giant hex with 16" props and 20Ah of battery! Since them telemetry radio is standard kit.
Thanks all, I will re-calibrate everything, go through auto-trim, then report back. I think I'm close. Cheers!
Are you rear motors turning the wrong directions? I've never built up a Y6, but I believe they spin opposite of the front motors. That would explain the odd motor output imbalance that shows up in your log files.
Ah interesting, thanks for the correction. I've never run an APM/Pixhawk Y6, but have been running one in the Y6A configuration with an Autoquad board for ages. Might try swapping it to a B layout and see how it flies.
Phillip and Glenn
There are two Y6 prop configuration options, Y6A and Y6B. However, there is only 1 correct choice Y6B.
Y6B has all the props spinning in the same direction on the top, and the opposite direction on the bottom. Y6B doesn't suffer from coupling between roll, pitch, and yaw axis.
If you fly with a Y6A, don't expect Autotune to work well because you are attempting to tune two axes at once.
He is using the Y6b setup, where all top props spin clockwise and the bottom ones anticlockwise,..
The one your talking about is the "old" Y6a setup.
Where do you see the output imbalance? It's set up with a "Y6B" layout (referenced on this wiki page) wherein all top motors turn one direction and all bottoms turn the other. You've got me wondering though, so I will double check that Y6B is selected! (just checked, indeed it is Y6B)
Yeah that rear prop pair definitely needs to be reversed to reduce the yaw imbalance that results from the reduced authority of the bottom props.
Do you have pics? Sorry if you already posted, but it helps to visually see a setup.
Here's my test quad aka "Dixie Cup". The landing gear is held together with Gorilla Glue; replacing it with hopefully better tomorrow. It really gets pushed hard.
Currently it has the Gemfan props. Well balanced, but there's always something I don't like about the way it flies. Yet after each new 3.3 rc, I put them back on to test.
I swear the next copter at some point will have folding props. So many I've talked to rave about them.
The sliding rails are intended to accommodate balance by sliding battery, gimbal, landing gear, and frame front to back. It would not come close to balance until I turned the battery sideways (funny looking, eh?). In front is a gimbal, GoPro, FPV camera, and vtx.
and bare frame at maiden before silly sideways battery or gimbal, and with crazy long landing gear when I was testing a 10000mAh; have since come to my senses on that:
The goal with this was so see if an extremely basic, small, portable/foldable Electrohub/hardware store build could be used for serious mapping. Easily repeatable, all off the shelf components for the most part.
Letting it pivot on two fingers it feels like CoG is close to perfect. Yet it really seems to want to drift forward in Alt Hold, but also slightly to the side, which is weird to me. So I may try shifting things back a bit to see if that makes a difference. Any other ideas? I can't move the battery further back without interfering with a prop. Cheers.
