could someone please tell me if this will fly?
im basically building the vehicle in my profile pic and i need to know if it will lift or better yet, aerobatic (in a sense)i got the motor with the closest specs the props required.props: 10x4.5motor:outrunnerC3542 KV1000 (on ebay, its £10, p+p=£10 with esc inc. is it too good to be true?)Rotational Speed :1000 (kv) RPM/VContinuous Current :45AMax. Current :55AInput Voltage :6 - 14.8VMax. Efficiency :98%No Load Current :1.8Aweight: 140g without escBattery:2200 mah14.8v lipo 4sthe servos are high torque and i expect the whole thing to weigh less than a kilogramone day all also want to attach FPV gear
    You should look at adapting one of the Gary Gress machines
    http://www.gressaero.com/
    He is a member here.
  • Agreed with the v tail. Because the motors tilt forward instead of lean forward like your typical drone should i make the battery shift its COG?
