Can anybody help analysing the cause of this crash?
The copter started a test mission without any troubles and after reaching a waypoint, he started to yaw constantly but continued to follow the mission path.
After a couple of seconds the pilot switched out of AUTO mode into PosHold and then down to STAB, but the copter kept on spinning. The resulting oscillation of trying to get the copter stable and dealing with the ongoing spin resulted in a crash.
When I looked at the log-files, I can see the actual yaw following the desired yaw nicely. Until this very certain waypoint where the desired yaw goes up to 360, stays there for 3 seconds and then drops to 0 and stays there - all still during AUTO mode. When the desired yaw goes up to 360, the copter started its constant yaw and did not stop unitil crashed.
We are aware of the z-vibrations being not super nice, but I am pretty sure that this is not the cause of this behaviour. The copter holds it's altitude pretty nicely.
Frame type is a X8.
Any ides or suggestions?
Any help is greatly appreciated!
Regards
Marc
10.BIN
2016-03-09 17-34-25.tlog
  • At work so can't look at the logs, but looking at the pics Cala posted, I had something similar (which I still haven't resolved). As Cala said, the vibes are suspicious. Also try looking at the EKF mag innovations. There's a howto on the wiki on how to analyze EKF log data. http://dev.ardupilot.com/wiki/extended-kalman-filter/#interpreting_...
  • Marc:
    I have a large Y6 and had a similar crash from uncontrollable yaw that started during a mission that started well.  After reviewing my log files I could not find a good reason as all data showed the controller attempting to stop the yaw.  In stabilize I could not effect the yaw.  In the end I concluded that some recent work to the motor mounts resulted in NOT doing the final tighting of one motor mount thru bolts, I expect the entire motor mount, with top and bottom motors and props, rotated on the arm during the flight and caused the uncontrolled yaw.  Its been months in a rebuild, all my fault.  Now I check the motor mounts every time I fly.
    Is there any chance the mounting blocks got loose somehow?
    • @Harry,
      loose mounting block can be easily detected in pre-flight diagnostics
      if you FFT Acc outputs amplitude and frequency don't match amplitude and frequency of airframe resonant vibrations.
      • Darius, You couldn't find your ass with  your own two hands and a flashlight.  I've asked you to profied your credentials but you have never responded with them.  I don't pretend to be perfect but you do yet you won't provide any of your abilities.   I therefore must assume you are a troll and only exist to be a thorn in the side of those who seek the truth.
        Why Darius hasn't been banned from this forum is beyond me.  I'm as much for Freedom as the next guy.  I'd die for the right of anyone to speak.  However, Darius hasn't added anything worthwhile to any discussion.  That he still has an account is a miracle that only God himself can explain!
      • Darius, checking the motor blocks is now a regular routine.  A difficult and expensive lesson I will never forget.
        How do you compare the resonant frequency of the frame to the Acc outputs in pre-flight diagnostics?
        In my case the motor blocks rotated after 3 minutes into the flight.  Pre-flight diagnostics showed everything was good to go.  Old fashion grab and twist is the only pre-flight test I have come up with.
        • T3
          Darius is talking about a hypothetical software solution to look at accelerometer data to try to ferret out loose mountings.
          I prefer a physical inspection, as you did Harry.  You're saying the mounting blocks became loose during flight?  Are you using any kind of threadlocker on the screws?
          • Typically, every nut, bolt, and thread have some type of nail glue or threadlocker.
            This one time I had disassembled my motor mounts, re-assembled, and perhaps tighten all but one set of blocks?  It's a question, as the damage was substantial.  Booms and four motors where broken or missing.  I was very lucky to recover and use all the expensive parts.  Its only my guess that this caused my crash.  Upon impact, all three battery connectors where pulled out, so no log file was recorded, however the telemetry log indicated the flight controller was taking the correct action to control the yaw, but had no effect.  That leads me to conclude this was a physical problem.  It makes me sick to think I was so stupid to allow this to happen.  Now I grab and twist every motor mount before every flight.
  • Marc: this what I noticed
    It's looks like your hardware couldn't follow what controller is telling to do at the begining of the event, so, I hope looks like a hardware problem; at the end you enter in panic and switch to many modes, you have to try to stay in stab and land.
    3702208157?profile=originalYour Clips doesn't looks good too; so something about vibes isn't good.
    3702208111?profile=originalIt's possible that you have something on your copter that it's hitting it? or wires? Your imu 1 is time to time out of desirable vibes
    3702207935?profile=original
    My 2 cents.
    • Cala, thanks for tuning in!
      I did not fly nor build the copter and the pilot couldn't remember exaclty when he switched back to manual mode or how long he tried to countersteer against the yaw.
      Can you tell me more about the Clips as it seems that I am not up to date with the latest logging/analysis possibilities?
      The guys managed to reduce the z-vibes to a fifth of its original magnitude, so this shouldnt be a problem any more.
May 21
Azjeg liked Azjeg's profile
Apr 27
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
