Cumulative Current Usage
A while back Mission Planner gave a percent usage for the battery that I assumed was based off the current data.  More recently that display has switched to the live current data.  Is there a setting in Mission Planner to go back to that previous percentage or ideally to show the cumulative current usage?  Ideally the low battery warning should trigger from either a low voltage and/or when the cumulative current usage passes the 80% of capacity mark.
  • If you right-click on the hud screen & select "user items".
    There is a check box named 'Battery_remaining'.
    It's not as nice looking as the previous battery charge display.
