I know this statement will raise the question who is this guy coming and telling us that current day autopilots are all wrong. Well I have been flying RC Planes from the age of 10 and have been using autopilots from the early Ardupilot of 2009 -2010 vintage till the more recent ones from 3DR, DJI, Feiyutech including their cheap clones over the last 5-6 years. I have been coding from the age of 15 and am now 21 years old.
Based on my experience with this wide range of autopilots I have come to the conclusion that hardware of majority of autopilots are adapted from the world of data based computing made for processing huge chunks of predefined data and giving a appropriate notification or display. In the case of data based computing inputs are got from low response data source like Ethernet/internet or some sensor network, this data is processed and outputs are either notifications or a display and in a few cases some very slow speed controls. Nothing where high speed control of a dynamic object is involved even on a single axis.
Hence the question : are these processors/hardware made for controlling a dynamic moving object with freedom across 3 axis’s like a drone??
After using all types of available autopilots I realized that the fundamentals of drone control at its core requires the following steps to be done repeatedly as fast as possible
1. reading sensor values and conveying them to the controller/processor
2. filtering these sensor values
3. pushing the filtered values into a PID loop
4. transferring control commands to the actuators for immediate action.
This cycle needs to be repeated over and over again the faster the better . This is what determines the stability of the drone the higher the cycle time the higher the stability .So what is needed in the case of drones is a continuous high speed input –output action reaction control system. I realized that drone control is not so much about data crunching as about speed of the control cycle.
If the use of drones has to grow developers have to be given freedom to code for their applications without compromising this core control cycle. In the case of drones a developers code resulting in a system hang will result in catastrophic outcomes like either crashs or fly aways, both which have been regularly reported in current autopilots. Achieving high control cycle speeds & isolating the flight controls is not possible with the current architecture of sequential processing, hence the future of drones is limited by the architecture of
currently available autopilots.
So unless a new thought process emerges drone use cannot grow exponentially. What is needed is a motherboard that it radically different from anything available today.
I have been working on this for a while now and my first hand experience is that the moment I shifted my focus to achieving higher speed control loops with my self designed autopilot the level of stability and performance I have been able to get are awesome even in very high costal wind speeds on a small 250 mm racer. I achieved this with the most primitive of micro controller used in the first ardupilot the ATMEGA 328. Things got even better when I replaced the MPU 6050. IMU with the MPU 9250.
With my custom made Distributed Parallel Control Computing Bus I have been able to achieve Altitude hold with a total drift accuracy of less than 1 meter and a very accurate heading hold as well as GPS navigation on the 250 mm racer. All I did was to add another ATMEGA 328 in parallel to the first one to add on features.
Thanks to this I am able to completely isolate the core flight control loop from the APP development coding there by the drone is never compromised by faulty APP development coding.
Distributed parallel control computing I have found from my own experience is an architecture that really has the potential to create exponential growth in drone applications. I would be interested to know of any other ways by which others are trying to address this core unique control processing requirements of drones.
Hello
From what I read :
muavdrones, you discarded the real-time OSes by merely having had a bad experience with FreeRTOS and semaphore overheat? There have been decades of research in RTOSes, multithreading is then unworthy? I do not get it. There are tens of RTOSes. Xenomai a adds a Linux micro-kernel extension and, pipelining sensitive and non-sensitive real-time calls differently, achieves <50µs at cyclic test on a Raspberry Pi (2 i guess). Do not you think you need to reconsider the option? I am genuinely asking since you know a lot more than me on this.
As per the architecture you proposed : can you go with me in the future? We are in 2022. Laser range finders have went through huge progress : they can now get 2Gb/s data streams at 360° both in horizontal and vertical field of view. You can map the entire surroundings within each sampling. Small "slamming" quadcopters autonomously determine agressive manoeuvres to go through tight spaces that cannot be reached with normal hover "in real-time" ( first vid there http://arstechnica.com/information-technology/2012/11/a-beautiful-r...). Will serial communication prove to not be a bottleneck, when your kinematic core will need to be constantly updated, with what you call environmental sensors ( often referred to, in the academic papers, as exteroceptive/exproprioceptive sensors)?
About RTOSes you can also think of Arinc653 for manned aviation...
It seems, muavdrones is blocked here ?
he cannot login anymore directly, but has to use a proxy
That has nothing to do with this DIYDrones website. It might that he's ISP in India have problems to connect NING network where this website is located.
I just checked his account and there are no any blockages assigned to his account.
Hope that network issues will be solved soon for him. In meanwhile if proxy works, then he can use proxy to access :)
@greg: you proposal is the same as PXF Cape for BBB, the NAVIO for RPi, PXF Mini for the RPi etc...
Not really the same as this proposal to use multiple microcontrollers for each fntion of the autopilot
Look like an interesting project for those wishing to use an Intel Edison. Nice.
more info please, does it support more then the intel Edison ?
Long live the Kahlman filter as a "very advanced SLAM algorithm", and advanced architectures where "even if the esc’s output Control doesn’t change every cycle , the motor Command changes based on PID and its previous OP". Also UARTs implementing the new Distributed Parallel Control Computing Bus.
And the Turing test.
Good luck with your project Venkat :)
1
2
3
4
5
of 9 Next
