Current Sensor for APM 2.5 (170A)
I have a new build coming up that's an Octo that I'm planning on using http://www.foxtechfpv.com/tmotor-351515-kv400-motor-p-822.html with 14x4.7 APC's. That pulls max current of 21A. Times 8 that's nearly 170A max. I'm wondering if there's a current sensor that can handle this? The attopilot has a 180A version, but has anyone actually pulled 180A through it (burst)?
If not is there anything that I can use?
On a side note, will using 6s batteries be an issue?
  • Who's PDB are you planning to use?
    Are you considering using the APM Power module to supply power to the APM?
    R Lefebvre has an octo build thread HERE.
    He could probably give you some good tips and ideas.
    -=Doug
