I have an octo and am installing a gimbal using the wiki. I've done this before on quads but not with an octo.
http://code.google.com/p/arducopter/wiki/AC2_Camera
Since I'm using digital servos, I wanted to set to another channel since A10 and A11 are 50hz. In the MP it doesn't allow choosing A9 but does allow A5-8. So I moved my pitch and roll to A7 and A8 and chose RC8 and RC9 in the MP. First it didn't work so I decided to change it back to A10 and A11. I'm just using the servo's signal wire and powering the servos via 6v BEC. I first changed the signal wires to A10 and A11 and then booted up the APM2.5 so I could change it to RC10 and RC11 in the MP. After about a minute or less, some of the motors spun up. Not so much to lift off but if someone was near one, they would have had some problem. Note that the Tx was on, MP was auto reconnecting and copter was of course disarmed. I had just plugged it in. So I pulled the battery and tried again. It happens every time. The only solution was to have someone hold down the octo while I changed the MP to use A10 and A11, then the motors stopped.
Is it possible the octo code is occupying these channels for some of it's motors? I noticed it was the same few motors each time.
What should I use for digital servos? A5 and A6?
I've raised an issue here and I hope we can fix it soon. Maybe for 3.0 'cuz we tend to prioritise safety issues.
F11music,
Thanks very much for the report. So the issue here is that you set it up so that it's trying to use RC7 and RC8 for the gimbal but on an octacopter those are used for the motors. So when it initialises the gimbal it fires up the motors! We should make this impossible 'cuz it'll never work and it's dangerous.
The other confusion is that on the side of the APM2.5 case RC10 and RC11 are labelled as A10 and A11 which makes you think that RC7 and RC8 must be the same as "A7" and "A8" but they're not. A7 and A8 are on the back of the APM2.5 where you already have your octo motors attached.
