datalogging info how to to ...
Hi!
I enabled all the available parameters that can be logged with the arducopter. These parameters are the following:
logs enabled:
ATTITUDE_FAST
ATTITUDE_MED
GPS
PM
CTUN
NTUN
RAW
CMD
CURRENT
MOTORS
OPTFLOW
Browsing the downloaded log, I see there's 12 data column in addition to the row designation and the variable column. The requested logs are only 11! Also if each of the attitude refers to the pitch, roll and yaw, that makes the total number of columns as 15 columns. Since there's no column designation given in the resulting table, can somebody help in assigning which column corresponds to what ...
On what is meant by each of the parameter ... attitude is pitch, roll and yaw but what is attitude_fast vis a vis attitude_med?; gps is self explanatory but should that occupy three columns for lat, long and altitude (further expanding the number of displayed columns in the table); what's PM, CTUN, NTUN, RAW, CMD? I assume current refers to battery (in amps?), what motor information is logged? OPTFLOW refers to optical flow which I don't have.
One more thing, I'd like to log the sonar and barometer values as the quad is flying around. How doI do that?
if info is already available, pardon the questions but a link to the information will be appreciated.
Thanks.
3690884575?profile=original
  • for some reason my  computer showed more information than before ... must be refresh rate or memory problem ... anyways, based on the datalogging link in  the wiki figured out the different parameters as well ... and guess what, sonar and baro alt showed up (go figure!) ... thks for looking anyways.3692255604?profile=original
