Default Parameter Values
Would it be at all possible to create a database containing exactly what the default parameter values are in each build?
We have all this wonderful color showing us supposedly where there is a problem, but we have no way of knowing aside from memory whether or not we have adjusted a value. Ideally APM should check the database once it retrieves the version your running and display that alongside the current values.
On a seperate note, it also would be nice to have an up to date reference of recommended changes to the default values, ie where some issue was discovered so the defaults *should* be changed.
Just some thoughts due to what is currently frustrating me.
Nathan
    I think I am right in saying that autotune will largely make that sort of issue go away.
