Difference between motors
2
I just completed building my new quad-C and made my first test flight. During testing I noted that one motor spun down much more quickly than the others, like it had much higher internal friction. In my short test flight I noticed that the copter had a tendency to pull in the direction of this motor. With is this because of the motor being more difficult to power? Do I need to replace the motor?
I thought that perhaps ESCs were capable of sensing the speed of the motor, so that all four motors would spin at the same speed regardless of their friction, is this correct? Or do they just give a certain amount of power and motors get the speed they get?
I'm hoping to learn something from your answers :-)
  • Does the motor have this 'internal friction' when the ESC is not powered? Is it possible your ESC is in brake mode?
  • T3
    Turn on motor log in the terminal mode and the review one of your flights.
  • Upon giving throttle input does all of your motors start simultaneously? If not you need to calibrate your ESC.  Here is link
    http://code.google.com/p/arducopter/wiki/AC2_ESC
