The wiki said to cut the trace which turns out to be no easy feat.  I did that and verified that the internal no longer working but I'm getting some odd random problems that make me think it's not a clean cut and it's popping in and out causing the APM to lock up while bench testing.
Can I simply remove the entire HMC5883L chip just to make sure or would removing that chip cause other problems?
    You can removed the whole chip if you want. That should not be a problem.
