Hi all,
I'm looking for some expert direction on what path I should take.
I have the following gear:
  • Stock Gaui 330X-S
  • Stock GAUI 330X Pan/Tilt Camera Mount
  • Spektrum DX6i Tx
  • Spektrum AR6210 Rx
  • 4 x Turnigy 3S 2200mAh 30C LiPo's
I have basic skills and knowledge of electronics and Adruidno however I'm not good with the programming side of things however I can copy/paste sketches and tweak them using advice from the internet.
I want to replace the stock gyro that comes with this quaddy with one of the above options.  I want to be able to have position and altitude hold mainly for AP.  I do however also like the sound of the ArduPilot however I'm not sure how much 'programming' I'd be required to do to get it working.
I like the DJI Naza because it will just do it.  However it is about $400 for the gyro/gps kit.  I like the ArduPilot because it means I can start playing with autopilot and waypoints etc but I'm not wanting to delve into the code to achieve it.
If most of what I want to do can be done through GUI with ArduPilot then that's what I'll go with.  If that's the case, can someone recommend me exactly what I need as I can see there are cut down version that might not have all the electronics I need etc.
I'm wanting a pre-built ArduPilot kit that I can just wire up configure and go.
Thanks in advance for all your assistance.
  • Thanks for all your help everyone.  I ended up going with the APM from what you've said.  I like to tinker and want a little bit of flexibility.  I'm fine with configuring and putting it all together it's just the code where I need some guidance but it looks like I won't really need to to much if any of that.  If I do, I'll just drop by here for some help.
    Thanks again.
  • I do own the apm2 and if its your 1ste fc board and you say not so good in the settings up stuff, i would go for the DJI.
  • If you want to tinker and have fun in the process= Ardupilot.
    If you want to just fly = DJI.
    You don't have to touch the code with APM--absolutely no programming required! It's a one-click firmware load with the Mission Planner. Totally GUI-driven; perhaps the easiest setup in the UAV market.
    Everything you need is here
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
