DO_SET_ROI / ROI : Howto use this option?
Hi all,
I have what appears to be a simple question: How can I let my quadopter fly a mission of 10 points and keep it oriented at a pre-defined point (the POI/ROI) during this mission?
To accomplish this I tried the "Set ROI" command in Mission Planner. This adds a line to the waypoint list called "DO_SET_ROI". It appears that my quad orients itself to the ROI on the way between the first two waypoints but for the rest of the mission it is pointed towards the next waypoint.
When I add more ROI points they seem to be ignored.
I'm flying a quadcopter with APM 2.5 hardware, an external compass and GPS module and firmware 3.1 RC2.
Did someone test the ROI functionality with firmware 3.1 RC2 and have success with it?
What parameters should I add to the DO_SET_ROI line in the waypoint list and why?
Best regards,
Jan Willem
The Netherlands
  • Today I tried the ROI and noticed the same as you: after the first waypoint it behaves following the setting of param "WP_YAW_BEHAVIOR".
    So what did I do...I manually inserted the same roi-command before each waypoint. You just save your mission to file, open it with notepad and copy/paste the line having "201" in the 4th column. Paste it just before every waypoint-command.Then resequence the line numbers. Don't know if this is necessary, didn't try without..
    Then "load" the edited file into mission planner and send it to your quad. Works perfect!
    I guess there's still some small bug somewhere. The webpage on mission planning (http://copter.ardupilot.com/wiki/planning-a-mission-with-waypoints-...) says you should use yaw-tracking option '3'. I tried all values, putting it in column 1,2,3 and 4 but no change of the initial behaviour. But for the time being, this solution does the job.
    Attached a sample that I used successfully. Have fun!
    Frank
    test5-works.txt
  • I also struggled with this. I wonder if you have to set an area as a Point Of Interest.  I so, how is this done?
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
yesterday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
