I removed Mission Planner from my computer, I was getting several pre arm check errors with mym2.8, I installed APMplanner 2, seemed super easy to go thru the set up, it was basically the same as Mission Planner, no errors, able to arm the motors, BUT, the throttle still acts funny, stick up just slightly and from idle to what seems like high rev, (what do I know tho, this is first build), saw a guy on YouTube with same problem but no fix, almost no range from just up from idle to 100% throttle, I put props on, hit the stick up and it revved, sounded sweet, I have Cobra Motors 2217/20 950Kv, stick all the way to the top and the thing won't budge, props are on right (1045s), motors spinning correct rotation direction, I'm thinking there is a setting either in the planner or the transmitter, someone out there knows, don't keep it a secret, let a fella in on it, lol, this is a new hobby for me and I'm a quadrotard, please help, any and all advice extremely appreciated
I'm real interested in the symptoms you're having with the motors going from low to high with only small stick movement. Also consider myself new to this but have been working through trying to recalibrate my ESCs. I should mention that I am building a Quad with an Ardupilot flight controller 2.6 and honestly not sure if I have a compatible Radio/Receiver using the Devo 10 radio. Welcome any comments on this.
If need any help with APM Planner 2.0, you can find help here on the ardupilot.org forums http://discuss.ardupilot.org/c/ground-control-software/apm-planner-2-0
Dan: Great to hear it. What was the fix?
Hi, I just experienced something similar with putting a Pixhawk in a fixed wing (P-39 Warplane). Basically what was happening was the Pixhawk would take too long to boot up and arm, and as a result the ESC would go into some sort of failsafe scenario and as a result it wouldn't go into calibration mode. I read somewhere that the trick was to use an USB connection (from computer) to pre-boot and then arm the Pixhawk first, and then plug the lipo in to the ESC. Doing this allowed me to correctly calibrate the ESC. Once the ESC was correctly calibrated, I no longer needed to pre-boot and arm the Pixhawk and everything now works as expected. Hope that helps.
Dan, Read the Wiki on telemetry logs and dataflash logs. Screen shots wont do it.
The real experts may be able to help, IF you can attach the log files to your post.
https://youtu.be/SbleSREn2Ew
Any ideas?
I'll try to do screen shots of actual board data as suggested by Harry C if i dont get it worked out,
Thanks to all with their advice thus far, im not going to give up, its frustrating and a challenge, im up for it even if i have to get another board to compare,
Someone out there knows how to fix this, please help
1
2
of 2 Next
