I have a Dx-7 and AR7000 tx/rx system and iv been playing around with the settings on Dx-7 but few questions came to light and wondered who could help me .
1) can I program the switches on the remote to control other ch apart from the standard stuff?
2) how do I get it to be able to flip trhu all flight modes because currently I can only set it up to flip between manual and what ever other flight mode I chose , I want control of all
3) my AR7000 is powering it self from the APM trhu any port is that okay?
4) on the DX-7 there are a Aux 1( gear) and Aux 2 but how do I make use of all the other switches because I'm only getting use out off Aux2
Any help welcome
Hi Johann,
My Easystar has ailerons, and a AR 6200 receiver, but I also use a DX7 transmitter.
I use the flap switch to control my 3 auto pilot modes and program the switch values as follows:-
Switch FLAP ELEV
NORM UP 50% 0%
MID DN 25% 0%
LAND DN 90% 0%
My autopilot is the the UAV Dev Board, so I put these values into the options header:-
#define MODE_SWITCH_THRESHOLD_LOW 2600
#define MODE_SWITCH_THRESHOLD_HIGH 3400
You may already have a scheme for progamming the failsafe. The Spektrum Rx continues to generate servo pulses when the signal fails, but it sends the throttle closed signal that it learnt when the Rx was "bound" to the TX. Before I bind the system, I program the Tx's throttle channels lowest value to LOW 150% (using the travel adjust menu). After binding I return the throttle's lowest value to LOW 100%. Then I use these failsafe values:-
#define FAILSAFE_INPUT_CHANNEL THROTTLE_INPUT_CHANNEL
#define FAILSAFE_INPUT_MIN 2000 // changed from 1500 for Spektrum radio
#define FAILSAFE_INPUT_MAX 4500
You can mix switched channels but it is very easy to get very mixed up. I did this with a DX5 which didn't have a 3 position switch.
Powering the Rx through any port is fine.
all the best.
Scouser
