DX7s ch7opt does not reach 1800 PWM
Dear all,
I try to setup my Spektrum DX7s for the CH7Opt.
I would like that the copter returns to launch when I switch the AIL/DR switch on my DX7s.
Unfortunately when is witch it, the max will not reach the 1800 (minimum) as it is necessary according to the manual (http://copter.ardupilot.com/wiki/channel-7-and-8-options/).
Any successions?
Thanks for your help.
Best regards
Thomas
  • Why dont you use AUX2 as Ch7
    I use ar7000 receiver configured for ch7
  • Sorry I am at the moment not in the office but as far as i remember i solved the problem by inverting the channel. Like this it reaches the 1800 easily but on the other side it doesn't go very low on the other side.
    I will post more details when I am back in the office.
    best regards
    Thomas
  • On the DX8 there is an option under servo setup called travel.
    You select travel and then select a channel on the radio
    If you increase that to past 100% (lets say 125%) it increases the PWM output on a specific channel
    Not sure if that option is available on the DX7 but if it is it might help getting to 1800
  • I have the same issue with DX6i. I would like to plug my ch6 receiver pin into input 7 on APM and trigger autotune that way, but the receiver output pin only reaches ~1700 pwm.
    I have thought of configuring a channel mix to increase the output pwm and see if that would bump it up over 1800, but I'm hoping there is a way to change the 1800 required to something lower.
    Is there a way to reduce that 1800 to 1700 or so?
