Dear all,
I try to setup my Spektrum DX7s for the CH7Opt.
I would like that the copter returns to launch when I switch the AIL/DR switch on my DX7s.
Unfortunately when is witch it, the max will not reach the 1800 (minimum) as it is necessary according to the manual (http://copter.ardupilot.com/wiki/channel-7-and-8-options/).
Any successions?
Thanks for your help.
Best regards
Thomas
I use ar7000 receiver configured for ch7
I will post more details when I am back in the office.
best regards
Thomas
On the DX8 there is an option under servo setup called travel.
You select travel and then select a channel on the radio
If you increase that to past 100% (lets say 125%) it increases the PWM output on a specific channel
Not sure if that option is available on the DX7 but if it is it might help getting to 1800
I have the same issue with DX6i. I would like to plug my ch6 receiver pin into input 7 on APM and trigger autotune that way, but the receiver output pin only reaches ~1700 pwm.
I have thought of configuring a channel mix to increase the output pwm and see if that would bump it up over 1800, but I'm hoping there is a way to change the 1800 required to something lower.
Is there a way to reduce that 1800 to 1700 or so?
