ebee VS ebee RTK
Hi everyone,
I am considering to purchase an ebee from sense fly, and I would love some feedback from ebee owners or ebee operators prior to my purchase. I also want to know more about the differences between the regular ebee and the rtk ebee system. My big picture questions would be:
   -How many acrees can the ebee map per flight?
   -What's the real RMSE (X,Y,Z) for the rtk and the non-rtk system?
   -Do I need to add GCP if I want to obtain a survey level accuracy (under 1cm) on the RTK system?
   -Does the rtk system come with the base station? or do i need to  budget for the base station too?
   -Can you operate the ebee inside cities? or How long does the landing area need to be?
Looking forward to hear from you all!
  • Hi Jordi,
    Better late than never. With any RTK system the best you will get reliably is 7-10cm accuracy. You may have days when you get down to 4cm accuracy. If you want better than 1cm accuracy then you will need to use ground control. Many of your questions can be answered by your local Ebee reseller.
