  • Have exactly the same question ?
    • I did try it once and got a copter wich was almost not flyable (it was flying pretymuch perfect with the default pid values).
      so i tuned it a little bit maunaly...
      Greetings
      • Ok Johannes, today I did my maiden flight with my fresh build slow fly quadcopter ( 15' carbon props and 360Kv motor )
        I've enabled EKF function with the parameter "AHRS_EKF_USE = 1" and tried to do an Autotune but got an
        "AUTOTUNE ERROR: Bad Gains (failed to determine proper gains) " and the copter does nothing in the air.
        I will try to disable EKF and do again an Autotune invoke when the weather allow me to fly
        Did you use EKF finally ?
        Wich copter did you use ?
        Thanks ;)
