EM-406a Lockup problem
After successfully getting the EM-406a to parse out data over the SiRf simulation software I attempted to use the standard GPS parsing code for the Adafruit GPS Logger Shield to send data over the serial inputs of an Arduino Mega.  Obviously communication pins 0 and 1 are used for the operation of the USB port on the Arduino Mega board.  Since this shield is suppose to be compatible with all the Arduinos does anyone have an idea on how to change the code and which of the uart pins to use that will work for the serial data?  Also what mode the EM-406a engine should be set to so that it outputs something the Arduino Mega can process?  I am a little stuck on this one.
Skip
Seattle, WA
