ESC calibrating without Power ?
I'm confuse about Arducopter units USB connection ?
When calibrating ? or setting up could we connect unit to USB ? [ ofcourse yes but after removing lipo connection right ? ]
Could i use Xbee for connecting ? is it work for configuration utility or mission planner ?
  • you can not calibrate the ESCs with the Configurator
    yes you can use Xbee connection (but you need to set it up correctly)
