ESC calibration motor "twitch"
Hey Folks,
I just built my ArduCopter kit from jDrones and all seems to be going well up until ESC calibration.  Looks like 3 out of the 4 ESCs work, but 1 makes the motor "twitch" sometimes--seems kind've random when it chooses to twitch or not (see vid).  I've tried the suspect ESC on another motor that didn't twitch and the suspect ESC makes it twitchy--so it looks like an ESC issue and not a motor.
Here's a video I made of the problem:
https://www.youtube.com/watch?v=Xc7Qfv-NFb8
Is my hardware broken? What should my next steps be? Buy a new ESC?  The bullet connections look solid.
Thanks,
Jeff
  • And if you give a little throttle and motor starts twitching, what happens if you help him to start spinning by hand?
    Swap the motor with another one to see which failed: the motor or the ESC.
    Do you really fly with your throttle inverted like that? Try reversing the throttle channel so neutral is low.
    Jason
  • Just FYI if it's not immediately obvious from the video, I'm following the MANUAL instructions here:
    http://code.google.com/p/arducopter/wiki/AC2_ESC
    PS I just re-soldered the bullets on the ESC and no change...
