ESC placement / power wiring
Hello I came up with this way of installing the ESCs that I found makes for a neat tucking away of cables.  Doing them one by one I noticed that by having the cabling take a natural route around the power board my routing ended up so that while an ESC is located underneath the power plate on one side, its control cable connect to the power board control outlet on the opposite side. And as it happens so does the motor cables. So a motor will correspond to the power board speed control connector on the same side as that motor. Should it turn out sides needs to be swapped around to match the APM sw then it´s simply a matter of swapping the control leads around and these have plenty of length.  I connect the input power cable of each ESC to the socket located 90 degrees clockwise ahead of the ESC. Which power socket you chose does not matter from a functional point of view since they are all interconnected. Use the one that makes for nice cable routing as I did here. I used four straps in total to hold wiring neatly.  My control cable wiring is wrong in the photo, but I´ll swap them around.
Per request, here are photos with the dome and platforms attached. I have some more electronics to mount before takeoff, but you get a sense of it.
  • I too would like to know if there are any heat issues with this setup, keep us posted!
  • This is a pretty neat solution.. much better then the "strap the ESC" to the arm one
  • I like how the connections from the ESC to the power distribution board are easy to access. This will make it MUCH easier to disconnect the ESC's when programming and configuring the board!
    If you can, could you post a picture of the dome attached when you have that done. I would like to see how it looks as an almost finish product.
