Using the link status in mission planner reveals that my connection is very poor.  RSSI is around 200 with very little noise.  The radios appear to connect fine and data does flow between the pixhawk and GCS, but the link stats shows that 4/5 packets don't make it.  I've replaced one of the radios, cables, etc but get the same outcome.  Any ideas?
  • Hi All
    I'm having link quality issue too using RFD900. At first I thought the area i operated had radio activities causing interference. We move to another distance location and this problem did not go away. The plane connects if it is within 300m, as soon as I move outside that range no link. I'm using EVENT's customized Mission planner based on Mission Planner v1.5.04, I hope this version naming by EVENT is consistent with original mission planner version. The Manufacturer recommended raise transmission power to 1W, but I don't see this makes any sense, if the issues is with the transmission power, I should get at least reasonable link quality when I'm that close. Any advise!
    Thanks in advance
  • Hi everyone,
    Happy new year to all!!!
    I use RFD900 modem with pixhawk and i have reached 10 kms out of home position flight successfully. I had put up my Ground Antennae high to achieve that. The real issue is, on the mission planner, during the flight the link quality was ranging between 95 to 98% . But when i replayed the logs in the mission planner, the HUD shows telemetry ranging from 50 to 98% during the flight.
    Any reason or suggestions???
  • I just updated mission planner to 1.3.23 and viola! 100% link quality.  Thanks for everyone's inputs and to Michael Oborne for jumping on this one.
    notice on the main hud it says 98% and in the other it shows 16-20%?
    this is because the 3dr radio injects packets that are not conforming to the correct sequence number.
    ie apm is doing the correct thing, hence the hud 98%.
    the 3dr radio is injecting packets for the rssi etc that have bad sequence numbers/duplicate packets
    Hi everyone.  Could I get some more info to try and chase the issue down?  There is obviously a problem as so many of you are experiencing it so we do need to find it.
    I suspect what some of you have suspected - that there is a bug in Mission Planner.  You could always download and run APMPlanner2 to see what it believes the packet loss is.
    The RSSI/REMRSSI and NOISE/REMNOISE values reported seem to be just fine and very unlikely to cause packet loss.  The SiK firmware for the radios hasn't changed in an age so that's unlikely to be it.  Which leaves the APM and MissionPlanner which change all the time.  I presume many of you have read through this page
    http://plane.ardupilot.com/wiki/common-optional-hardware/common-tel...
    and done the graphing analysis?  If there is a clear gap (the larger the better) between your RSSI lines and your NOISE graph lines you should be all good.
    Could I please get the following to do the analysis:
    Has everyone upgraded to the latest Mission Planner and if not could you please do so.
    What version of APM is everyone running in their vehicles - vehicle type would be good too i.e. rover, plane, copter?
    And critically could we get the dataflash logs and the tlog of a session running when the packet loss was very high please?
    Thanks, Grant
  • I found high packet loss with a v2 radio on my copter and v2 plugged into my laptop. The same radio plugged into an android phone gave 100% link quality. An old v1 radio works to 100% link quality both plugged into laptop or phone...
