Hi Jason!
Would it be possible to have a modified altitude hold mode, but with the capability of changing altitude?
Bear with me ;)
Lets say the copter is on the ground and the throttle is at 0%. We select alt_hold2.
Increase the throttle to 50%. The copter starts up but doesnt take off.
We increase the throttle to say 70%. The copter takes off slowly then starts to climb.
We reduce throttle to 50%. It then holds the alttitude its at.
We reduce the throttle to 30% and it decends.
We again go back to 50% and it holds that altitude.
I tried to explain it as simply as I could to avoid confusion. Mainly my own ;)
I guess the summary would be an altitude hold mode that we can change manually change the altitude using the throttle.
0-40% throttle - copter decends
40-60% throttle - copter maintains altitude
60-100% throttle - copter climbs.
Settings for the mode could be the ability to change the above figures and the rate at which the copter climbs or descends.
What do you think?
G
I run 2.0.49 and I can adjust height in alt.hold mode using throttle stick. The only problem is that I have to give 100% throttle to activate this, and it's very violent behaviour. There is no in between, just full power upwards.
