Faster ArduIMU?
I have been trying to edit the ArduIMU 1.8.2 code so that it would run faster (increased Hz) to no avail. I want to know if there is a faster way of just getting simple roll, pitch, & yaw angles out of the thing... I know that when you connect the ArduIMU to the ArduPilot, you connect digital pin 8 (IMU) to the ardupilot. does anyone know what this does? does anyone know of any faster ways to get data out of it?
thanks!
  • anyone like the results they see? any improvements are welcome
  • The above have been tested and work pretty well. No guarantees, but for what i've been doing, it works great.
  • (output.pde)
    void printdata(void)
    #if PRINT_BINARY != 1  //Print either Ascii or binary messages
        Serial.print("!");
        //Serial.print(SOFTWARE_VER);  //output the software version
        //Serial.print(",");
        #if PRINT_ANALOGS==1
            Serial.print("AN0:");
            Serial.print(read_adc(0)); //Reversing the sign.
            Serial.print(",AN1:");
            Serial.print(read_adc(1));
            Serial.print(",AN2:");
            Serial.print(read_adc(2));
            Serial.print(",AN3:");
            Serial.print(read_adc(3));
            Serial.print (",AN4:");
            Serial.print(read_adc(4));
            Serial.print (",AN5:");
            Serial.print(read_adc(5));
            Serial.print (",");
        #endif
        #if PRINT_DCM == 1
            Serial.print ("EX0:");
            Serial.print(convert_to_dec(DCM_Matrix[0][0]));
            Serial.print (",EX1:");
            Serial.print(convert_to_dec(DCM_Matrix[0][1]));
            Serial.print (",EX2:");
            Serial.print(convert_to_dec(DCM_Matrix[0][2]));
            Serial.print (",EX3:");
            Serial.print(convert_to_dec(DCM_Matrix[1][0]));
            Serial.print (",EX4:");
            Serial.print(convert_to_dec(DCM_Matrix[1][1]));
            Serial.print (",EX5:");
            Serial.print(convert_to_dec(DCM_Matrix[1][2]));
            Serial.print (",EX6:");
            Serial.print(convert_to_dec(DCM_Matrix[2][0]));
            Serial.print (",EX7:");
            Serial.print(convert_to_dec(DCM_Matrix[2][1]));
            Serial.print (",EX8:");
            Serial.print(convert_to_dec(DCM_Matrix[2][2]));
            Serial.print (",");
        #endif
        #if PRINT_EULER == 1
            Serial.print(ToDeg(roll));
            Serial.print(",");
            Serial.print(ToDeg(pitch));
            Serial.print(",");
            Serial.print(ToDeg(yaw));
            Serial.print(",");
            Serial.print((imu_health>>8)&0xff);
            Serial.print (",");
        #endif
        #if USE_MAGNETOMETER == 1
            Serial.print("MGX:");
            Serial.print(magnetom_x);
            Serial.print (",MGY:");
            Serial.print(magnetom_y);
            Serial.print (",MGZ:");
            Serial.print(magnetom_z);
            Serial.print (",MGH:");
            Serial.print(MAG_Heading);
            Serial.print (",");
        #endif
        #if USE_BAROMETER == 1
            Serial.print("Temp:");
            Serial.print(temp_unfilt/20.0);      // Convert into degrees C
            alti();
            Serial.print(",Pressure: ");
            Serial.print(press);
    //        Serial.print(press>>2);       // Convert into Pa
            Serial.print(",Alt: ");
            Serial.print(press_alt/1000);  // Original floating point full solution in meters
            Serial.print (",");
        #endif
        #if PRINT_GPS == 1
            Serial.print("LAT:");
            Serial.print(GPS.latitude);
            Serial.print(",");
            Serial.print(GPS.longitude);
            Serial.print(",");
            Serial.print(GPS.altitude/100);    // meters
            Serial.print(",");
            Serial.print(GPS.ground_course/100);    // degrees
            Serial.print(",");
            Serial.print(GPS.ground_speed/100);
            Serial.print(",");
            Serial.print((int)GPS.fix);        // 1 = good fix
            Serial.print(",");
            Serial.print((int)GPS.num_sats);
            Serial.print (",");
            #if PERFORMANCE_REPORTING == 1
                gps_messages_sent++;
            #endif
        #endif
        Serial.print("TOW:");
        Serial.print(GPS.time);
        Serial.println("***");
    #else
        //  This section outputs binary data messages
        //  Conforms to new binary message standard (12/31/09)
        byte IMU_buffer[22];
        int tempint;
        int ck;
        long templong;
        byte IMU_ck_a=0;
        byte IMU_ck_b=0;
        //  This section outputs the gps binary message when new gps data is available
        if(GPS.new_data==1) {
            #endif
            GPS.new_data=0;
            Serial.print("DIYd");  // This is the message preamble
            IMU_buffer[0]=0x13;
            ck=19;
            IMU_buffer[1] = 0x03;
            templong = GPS.longitude; //Longitude *10**7 in 4 bytes
            IMU_buffer[2]=templong&0xff;
            IMU_buffer[3]=(templong>>8)&0xff;
            IMU_buffer[4]=(templong>>16)&0xff;
            IMU_buffer[5]=(templong>>24)&0xff;
            templong = GPS.latitude; //Latitude *10**7 in 4 bytes
            IMU_buffer[6]=templong&0xff;
            IMU_buffer[7]=(templong>>8)&0xff;
            IMU_buffer[8]=(templong>>16)&0xff;
            IMU_buffer[9]=(templong>>24)&0xff;
            #if USE_BAROMETER==0
                tempint=GPS.altitude / 100;   // Altitude MSL in meters * 10 in 2 bytes
            #else
                alti();
                tempint = (press_alt * ALT_MIX + GPS.altitude * (100-ALT_MIX)) / 10000;    //Blended GPS and pressure altitude
            #endif
            IMU_buffer[10]=tempint&0xff;
            IMU_buffer[11]=(tempint>>8)&0xff;
            tempint=GPS.ground_speed;   // Speed in M/S * 100 in 2 bytes
            IMU_buffer[12]=tempint&0xff;
            IMU_buffer[13]=(tempint>>8)&0xff;
            tempint=GPS.ground_course;   // course in degreees * 100 in 2 bytes
            IMU_buffer[14]=tempint&0xff;
            IMU_buffer[15]=(tempint>>8)&0xff;
            IMU_buffer[16]=GPS.time&0xff;
            IMU_buffer[17]=(GPS.time>>8)&0xff;
            IMU_buffer[18]=(GPS.time>>16)&0xff;
            IMU_buffer[19]=(GPS.time>>24)&0xff;
                IMU_buffer[20]=(imu_health>>8)&0xff;
            for (int i=0;i<ck+2;i++) Serial.print (IMU_buffer[i]);
            for (int i=0;i<ck+2;i++) {
                IMU_ck_a+=IMU_buffer[i];  //Calculates checksums
                IMU_ck_b+=IMU_ck_a;
              Serial.print(IMU_ck_a);
              Serial.print(IMU_ck_b);
        } else {
            // This section outputs the IMU orientatiom message
            IMU_buffer[0]=0x06;
            ck=6;
            IMU_buffer[1] = 0x02;
            tempint=ToDeg(roll)*100;  //Roll (degrees) * 100 in 2 bytes
            IMU_buffer[2]=tempint&0xff;
            IMU_buffer[3]=(tempint>>8)&0xff;
            tempint=ToDeg(pitch)*100;   //Pitch (degrees) * 100 in 2 bytes
            IMU_buffer[4]=tempint&0xff;
            IMU_buffer[5]=(tempint>>8)&0xff;
            templong=ToDeg(yaw)*100;  //Yaw (degrees) * 100 in 2 bytes
            if(templong>18000) templong -=36000;
            if(templong<-18000) templong +=36000;
            tempint = templong;
            IMU_buffer[6]=tempint&0xff;
            IMU_buffer[7]=(tempint>>8)&0xff;
                IMU_ck_b+=IMU_ck_a;
    #endif
    void printPerfData(long time)
    // This function outputs a performance monitoring message (used every 20 seconds)
    //  Can be either binary or human readable
    #if PRINT_BINARY == 1
          byte IMU_buffer[30];
          int ck;
          byte IMU_ck_a=0;
          byte IMU_ck_b=0;
            IMU_buffer[0]=0x11;
            ck=17;
              IMU_buffer[1] = 0x0a;
                //Time for this reporting interval in millisecons
                IMU_buffer[2]=time&0xff;
                IMU_buffer[3]=(time>>8)&0xff;
                IMU_buffer[4]=(time>>16)&0xff;
                IMU_buffer[5]=(time>>24)&0xff;
                IMU_buffer[6]=mainLoop_count&0xff;
                IMU_buffer[7]=(mainLoop_count>>8)&0xff;
                IMU_buffer[8]=G_Dt_max&0xff;
                IMU_buffer[9]=(G_Dt_max>>8)&0xff;
                IMU_buffer[10]=gyro_sat_count;
                IMU_buffer[11]=adc_constraints;
                IMU_buffer[12]=renorm_sqrt_count;
                IMU_buffer[13]=renorm_blowup_count;
                IMU_buffer[14]=0;                                // gps_payload_error_count - We don't have access to this with GPS library
                IMU_buffer[15]=0;                                // gps_checksum_error_count - We don't have access to this with GPS library
                IMU_buffer[16]=0;                                // gps_pos_fix_count - We don't have access to this with GPS library
                IMU_buffer[17]=0;                                // gps_nav_fix_count - We don't have access to this with GPS library
                IMU_buffer[18]=gps_messages_sent;                // This metric is equal to the number of gps fixes received
                      IMU_ck_b+=IMU_ck_a;
    #else
        Serial.print("PPP");
        Serial.print("pTm:");
        Serial.print(time,DEC);
        Serial.print(",mLc:");
        Serial.print(mainLoop_count,DEC);
        Serial.print(",DtM:");
        Serial.print(G_Dt_max,DEC);
        Serial.print(",gsc:");
        Serial.print(gyro_sat_count,DEC);
        Serial.print(",adc:");
        Serial.print(adc_constraints,DEC);
        Serial.print(",rsc:");
        Serial.print(renorm_sqrt_count,DEC);
        Serial.print(",rbc:");
        Serial.print(renorm_blowup_count,DEC);
        Serial.print(",gms:");
        Serial.print(gps_messages_sent,DEC);
        Serial.print(",imu:");
        Serial.print((imu_health>>8),DEC);
        Serial.print(",***");
    #endif
            // Reset counters
            mainLoop_count = 0;
            G_Dt_max  = 0;
            gyro_sat_count = 0;
            adc_constraints = 0;
            renorm_sqrt_count = 0;
            renorm_blowup_count = 0;
            gps_messages_sent = 0;
    #endif
    long convert_to_dec(float x)
      return x*10000000;
  • So here is my ammended ArduIMU code, the output files and the main loop are the only ones I have changed, so the rest are not included.
    (arduimu.pde)
    // Released under Creative Commons License
    // Code by Jordi Munoz and William Premerlani, Supported by Chris Anderson and Doug Weibel
    // Version 1.0 for flat board updated by Doug Weibel and Jose Julio
    // Version 1.7 includes support for SCP1000 absolute pressure sensor
    // Version 1.8 uses DIYDrones GPS, FastSerial, and Compass libraries
    // Axis definition: X axis pointing forward, Y axis pointing to the right and Z axis pointing down.
    // Positive pitch : nose up
    // Positive roll : right wing down
    // Positive yaw : clockwise
    #include <avr/eeprom.h>
    #include <Wire.h>
    #include <FastSerial.h>        // ArduPilot Fast Serial Library
    #include <AP_GPS.h>        // ArduPilot GPS library
    #include <APM_Compass.h>    // ArduPilot Mega Magnetometer Library
    //  This section contains USER PARAMETERS !!!
    // *** NOTE!   Hardware version - Can be used for v1 (daughterboards) or v2 (flat)
    #define BOARD_VERSION 2 // 1 For V1 and 2 for V2
    #define GPS_CONNECTION 1 // 0 for GPS pins, 1 for programming pins
    // GPS Type Selection - Note Ublox or MediaTek is recommended.  Support for NMEA is limited.
    #define GPS_PROTOCOL 1    // 1 - NMEA,  2 - EM406,  3 - Ublox, 4 -- MediaTek
    // Enable Air Start uses Remove Before Fly flag - connection to pin 6 on ArduPilot
    #define ENABLE_AIR_START 0  //  1 if using airstart/groundstart signaling, 0 if not
    #define GROUNDSTART_PIN 8    //  Pin number used for ground start signal (recommend 10 on v1 and 8 on v2 hardware)
    /*Min Speed Filter for Yaw drift Correction*/
    #define SPEEDFILT 2 // >1 use min speed filter for yaw drift cancellation (m/s), 0=do not use speed filter
    /*For debugging propurses*/
    #define PRINT_DEBUG 0   //Will print Debug messages
    //OUTPUTMODE=1 will print the corrected data, 0 will print uncorrected data of the gyros (with drift), 2 will print accelerometer only data
    #define OUTPUTMODE 1
    #define PRINT_DCM 0     //Will print the whole direction cosine matrix
    #define PRINT_ANALOGS 0 //Will print the analog raw data
    #define PRINT_EULER 1   //Will print the Euler angles Roll, Pitch and Yaw
    #define PRINT_GPS 1     //Will print GPS data
    // *** NOTE!   To use ArduIMU with ArduPilot you must select binary output messages (change to 1 here)
    #define PRINT_BINARY 0  //Will print binary message and suppress ASCII messages (above)
    // *** NOTE!   Performance reporting is only supported for Ublox.  Set to 0 for others
    #define PERFORMANCE_REPORTING 0  //Will include performance reports in the binary output ~ 1/2 min
    /* Support for optional magnetometer (1 enabled, 0 dissabled) */
    #define USE_MAGNETOMETER 0 // use 1 if you want to make yaw gyro drift corrections using the optional magnetometer
    // Local magnetic declination
    // I use this web : http://www.ngdc.noaa.gov/geomagmodels/Declination.jsp
    #define MAGNETIC_DECLINATION -20.0    // corrects magnetic bearing to true north
    /* Support for optional barometer (1 enabled, 0 dissabled) */
    #define USE_BAROMETER 0     // use 1 if you want to get altitude using the optional absolute pressure sensor
    #define ALT_MIX    50            // For binary messages: GPS or barometric altitude.  0 to 100 = % of barometric.  For example 75 gives 25% GPS alt and 75% baro
    //  End of user parameters
    #define SOFTWARE_VER "C-1.8.2"
    // GPS Selection
    FastSerialPort0(Serial);        // Instantiate the fast serial driver
    #if   GPS_PROTOCOL == 1
    AP_GPS_NMEA        GPS(&Serial);
    #elif GPS_PROTOCOL == 2
    AP_GPS_406        GPS(&Serial);
    #elif GPS_PROTOCOL == 3
    AP_GPS_UBLOX        GPS(&Serial);
    #elif GPS_PROTOCOL == 4
    AP_GPS_MTK        GPS(&Serial);
    #else
    # error Must define GPS_PROTOCOL with a valid value.
    #endif
    // ADC : Voltage reference 3.3v / 10bits(1024 steps) => 3.22mV/ADC step
    // ADXL335 Sensitivity(from datasheet) => 330mV/g, 3.22mV/ADC step => 330/3.22 = 102.48
    // Tested value : 101
    #define GRAVITY 101 //this equivalent to 1G in the raw data coming from the accelerometer
    #define Accel_Scale(x) x*(GRAVITY/9.81)//Scaling the raw data of the accel to actual acceleration in meters for seconds square
    #define ToRad(x) (x*0.01745329252)  // *pi/180
    #define ToDeg(x) (x*57.2957795131)  // *180/pi
    // LPR530 & LY530 Sensitivity (from datasheet) => 3.33mV/º/s, 3.22mV/ADC step => 1.03
    // Tested values : 0.96,0.96,0.94
    #define Gyro_Gain_X 0.92 //X axis Gyro gain
    #define Gyro_Gain_Y 0.92 //Y axis Gyro gain
    #define Gyro_Gain_Z 0.94 //Z axis Gyro gain
    #define Gyro_Scaled_X(x) x*ToRad(Gyro_Gain_X) //Return the scaled ADC raw data of the gyro in radians for second
    #define Gyro_Scaled_Y(x) x*ToRad(Gyro_Gain_Y) //Return the scaled ADC raw data of the gyro in radians for second
    #define Gyro_Scaled_Z(x) x*ToRad(Gyro_Gain_Z) //Return the scaled ADC raw data of the gyro in radians for second
    #define Kp_ROLLPITCH 0.015
    #define Ki_ROLLPITCH 0.000010
    #define Kp_YAW 1.2
    //#define Kp_YAW 2.5      //High yaw drift correction gain - use with caution!
    #define Ki_YAW 0.00005
    #define ADC_WARM_CYCLES 75
    #define FALSE 0
    #define TRUE 1
    float G_Dt=0.02;    // Integration time (DCM algorithm)
    long timeNow=0; // Hold the milliseond value for now
    long timer=0;   //general purpuse timer
    long timer_old;
    long timer24=0; //Second timer used to print values
    boolean groundstartDone = false;    // Used to not repeat ground start
    float AN[8]; //array that store the 6 ADC filtered data
    float AN_OFFSET[8]; //Array that stores the Offset of the gyros
    float Accel_Vector[3]= {0,0,0}; //Store the acceleration in a vector
    float Gyro_Vector[3]= {0,0,0};//Store the gyros rutn rate in a vector
    float Omega_Vector[3]= {0,0,0}; //Corrected Gyro_Vector data
    float Omega_P[3]= {0,0,0};//Omega Proportional correction
    float Omega_I[3]= {0,0,0};//Omega Integrator
    float Omega[3]= {0,0,0};
    // Euler angles
    float roll;
    float pitch;
    float yaw;
    int toggleMode=0;
    float errorRollPitch[3]= {0,0,0};
    float errorYaw[3]= {0,0,0};
    float errorCourse=180;
    float COGX=0; //Course overground X axis
    float COGY=1; //Course overground Y axis
    unsigned int cycleCount=0;
    byte gyro_sat=0;
    float DCM_Matrix[3][3]= {
        1,0,0  }
        0,1,0  }
        0,0,1  }
    float Update_Matrix[3][3]={{0,1,2},{3,4,5},{6,7,8}}; //Gyros here
    float Temporary_Matrix[3][3]={
        0,0,0  }
        0,0,0  }
        0,0,0  }
    // Startup GPS variables
    int gps_fix_count = 5;        //used to count 5 good fixes at ground startup
    //ADC variables
    volatile uint8_t MuxSel=0;
    volatile uint8_t analog_reference = DEFAULT;
    volatile uint16_t analog_buffer[8];
    volatile uint8_t analog_count[8];
     #if BOARD_VERSION == 1
      uint8_t sensors[6] = {0,2,1,3,5,4};   // Use these two lines for Hardware v1 (w/ daughterboards)
      int SENSOR_SIGN[]= {1,-1,1,-1,1,-1,-1,-1,-1};  //Sensor: GYROX, GYROY, GYROZ, ACCELX, ACCELY, ACCELZ
     #endif
     #if BOARD_VERSION == 2
      uint8_t sensors[6] = {6,7,3,0,1,2};  // For Hardware v2 flat
      int SENSOR_SIGN[] = {1,-1,-1,1,-1,1,-1,-1,-1};
     #endif
     // Performance Monitoring variables
     // Data collected and reported for ~1/2 minute intervals
     int mainLoop_count = 0;              //Main loop cycles since last report
     int G_Dt_max = 0.0;                  //Max main loop cycle time in milliseconds
     byte gyro_sat_count = 0;
     byte adc_constraints = 0;
     byte renorm_sqrt_count = 0;
     byte renorm_blowup_count = 0;
     byte gps_messages_sent = 0;
     long perf_mon_timer = 0;
     #endif
     unsigned int imu_health = 65012;
    //  This section contains SCP1000_D11 PARAMETERS !!!
    #define SCP_MODE        (9)             // 9 = high speed mode, 10 = high resolution mode
    #define PRESSURE_ADDR   (0x11U)          // IIC address of the SCP1000
    // ************   #define START_ALTITUDE  (217U)           // default initial altitude in m above sea level
    // When we have to manage data transfers via IIC directly we need to use the following addresses
    // IIC address of the SCP1000 device forms the Top 7 bits of the address with the R/W bit as the LSB
    #define READ_PRESSURE_ADDR    (PRESSURE_ADDR<<1 | 1)
    #define WRITE_PRESSURE_ADDR   (PRESSURE_ADDR<<1)
    // SCP1000 Register addresses
    #define SNS_ADDR_POPERATION     (0x03U)  // OPERATON register
    #define SNS_ADDR_PSTATUS        (0x07U)  // STATUS register
    #define SNS_ADDR_PPRESSURE      (0x80U)  // DATARD16 Register (pressure)
    #define SNS_ADDR_DATARD8    (0x7FU)  // DAYARD8 Register
    #define SNS_ADDR_PTEMP        (0x81U)     // TEMPOUT Register (temperature)
    #ifndef TRUE
    #define TRUE          (0x01)
    #endif
    #ifndef FALSE
    #define FALSE         (0x00)
    #endif
    int temp_unfilt = 0;
    int temperature = 0;
    unsigned long press = 0;
    unsigned long press_filt = 0;
    unsigned long press_gnd = 0;
    long ground_alt = 0;                // Ground altitude in centimeters
    long press_alt = 0;                    // Pressure altitude in centimeters
    #endif
    void setup()
      Serial.begin(38400, 128, 16);
      pinMode(2,OUTPUT); //Serial Mux
      if (GPS_CONNECTION == 0){
        digitalWrite(2,HIGH); //Serial Mux
      } else {
        digitalWrite(2,LOW); //Serial Mux
      pinMode(5,OUTPUT); //Red LED
      pinMode(6,OUTPUT); // Blue LED
      pinMode(7,OUTPUT); // Yellow LED
      pinMode(GROUNDSTART_PIN,INPUT);  // Remove Before Fly flag (pin 6 on ArduPilot)
      digitalWrite(GROUNDSTART_PIN,HIGH);
      digitalWrite(5,HIGH);
      delay(500);
      digitalWrite(6,HIGH);
      delay(500);
      digitalWrite(7,HIGH);
      delay(500);
      digitalWrite(5,LOW);
      delay(500);
      digitalWrite(6,LOW);
      delay(500);
      digitalWrite(7,LOW);
      Analog_Reference(EXTERNAL);//Using external analog reference
      Analog_Init();
      debug_print("Welcome...");
      debug_print("You are using Hardware Version 1...");
      #endif
      debug_print("You are using Hardware Version 2...");
      #endif
      GPS.init();            // GPS Initialization
      debug_handler(0);        //Printing version
          APM_Compass.Init();    // I2C initialization
          debug_handler(3);
      #endif
      // SETUP FOR SCP1000_D11
        #if USE_BAROMETER==1
            debug_handler(4);
            setup_scp();
        #endif
      if(ENABLE_AIR_START){
          debug_handler(1);
          startup_air();
      }else{
          debug_handler(2);
          startup_ground();
      delay(250);
      Read_adc_raw();     // ADC initialization
      timer=DIYmillis();
      delay(20);
    void loop() //Main Loop
      timeNow = millis();
      if((timeNow-timer)>=20)  // Main loop runs at 50Hz
        timer_old = timer;
        timer = timeNow;
        mainLoop_count++;
        if (timer-timer_old > G_Dt_max) G_Dt_max = timer-timer_old;
    #endif
        G_Dt = (timer-timer_old)/1000.0;    // Real time of loop run. We use this on the DCM algorithm (gyro integration time)
        if(G_Dt > 1)
            G_Dt = 0;  //Something is wrong - keeps dt from blowing up, goes to zero to keep gyros from departing
        // *** DCM algorithm
        Read_adc_raw();
        Matrix_update();
        Normalize();
        Drift_correction();
        Euler_angles();
    //    #if PRINT_BINARY == 1
          printdata(); //Send info via serial
    //    #endif
        //Turn on the LED when you saturate any of the gyros.
        if((abs(Gyro_Vector[0])>=ToRad(300))||(abs(Gyro_Vector[1])>=ToRad(300))||(abs(Gyro_Vector[2])>=ToRad(300)))
          gyro_sat=1;
          gyro_sat_count++;
    #endif
        cycleCount++;
            // Do these things every 6th time through the main cycle
            // This section gets called every 1000/(20*6) = 8 1/3 Hz
            // doing it this way removes the need for another 'millis()' call
            // and balances the processing load across main loop cycles.
            switch (cycleCount) {
                case(0):
                    GPS.update();
                    break;
                case(1):
                    //Here we will check if we are getting a signal to ground start
                    if(digitalRead(GROUNDSTART_PIN) == LOW && groundstartDone == false)
                        startup_ground();
                    break;
                case(2):
                        ReadSCP1000();    // Read I2C absolute pressure sensor
                        press_filt = (press + 2l * press_filt) / 3l;        //Light filtering
                        //temperature = (temperature * 9 + temp_unfilt) / 10;    We will just use the ground temp for the altitude calculation
                    #endif
                    break;
                case(3):
                    #if USE_MAGNETOMETER==1
                    APM_Compass.Read();     // Read magnetometer
                    APM_Compass.Calculate(roll,pitch);  // Calculate heading
                    #endif
                    break;
                case(4):
                    // Display Status on LEDs
                    // GYRO Saturation indication
                    if(gyro_sat>=1) {
                        digitalWrite(5,HIGH); //Turn Red LED when gyro is saturated.
                        if(gyro_sat>=8)  // keep the LED on for 8/10ths of a second
                            gyro_sat=0;
                        else
                            gyro_sat++;
                    } else {
                    // YAW drift correction indication
                    if(GPS.ground_speed<SPEEDFILT*100) {
                        digitalWrite(7,HIGH);    //  Turn on yellow LED if speed too slow and yaw correction supressed
                    } else {
                    // GPS Fix indication
                                    switch (GPS.status()) {
                                            case(2):
                              digitalWrite(6,HIGH);  //Turn Blue LED when gps is fixed.
                                                  break;
                                            case(1):
                                                  if (GPS.valid_read == true){
                                                        toggleMode = abs(toggleMode-1); // Toggle blue light on and off to indicate NMEA sentences exist, but no GPS fix lock
                                                        if (toggleMode==0){
                                                              digitalWrite(6, LOW); // Blue light off
                                                        } else {
                                                              digitalWrite(6, HIGH); // Blue light on
                                                        GPS.valid_read = false;
                                                  break;
                                            default:
                                                  break;
                    break;
                case(5):
                    cycleCount = -1;        // Reset case counter, will be incremented to zero before switch statement
                    #if !PRINT_BINARY
                        //printdata(); //Send info via serial
                    #endif
                    break;
        if (timeNow-perf_mon_timer > 20000)
          printPerfData(timeNow-perf_mon_timer);
          perf_mon_timer=timeNow;
    #endif
    void startup_ground(void)
        uint16_t store=0;
        int flashcount = 0;
        debug_handler(2);
        for(int c=0; c<ADC_WARM_CYCLES; c++)
            delay(50);
            Read_adc_raw();
            delay(50);
        Read_adc_raw();
        delay(20);
        Read_adc_raw();
        for(int y=0; y<=5; y++)   // Read first initial ADC values for offset.
            AN_OFFSET[y]=AN[y];
        ReadSCP1000();
        press_gnd = press;
        temperature = temp_unfilt;
        delay(20);
    #endif
        for(int i=0;i<400;i++)    // We take some readings...
            Read_adc_raw();
            for(int y=0; y<=5; y++)   // Read initial ADC values for offset (averaging).
                AN_OFFSET[y]=AN_OFFSET[y]*0.8 + AN[y]*0.2;
            delay(20);
            if(flashcount == 5) {
            if(flashcount >= 10) {
                flashcount = 0;
                ReadSCP1000();
                press_gnd = (press_gnd * 9l + press) / 10l;
    #endif
            flashcount++;
        AN_OFFSET[5]-=GRAVITY*SENSOR_SIGN[5];
            Serial.println(AN_OFFSET[y]);
            store = ((AN_OFFSET[y]-200.f)*100.0f);
            eeprom_busy_wait();
            eeprom_write_word((uint16_t *)    (y*2+2), store);
        while (gps_fix_count > 0 && USE_BAROMETER) {
            GPS.update();
    //  Serial.print(gpsFix);
    //  Serial.print(", ");
    //  Serial.println(gpsFixnew);
            if (GPS.fix == 1 && GPS.new_data == 1) {
                GPS.new_data = 0;
                gps_fix_count--;
        press_filt = press_gnd;
        ground_alt = GPS.altitude;
        eeprom_busy_wait();
        eeprom_write_dword((uint32_t *)0x10, press_gnd);
        eeprom_busy_wait();
        eeprom_write_word((uint16_t *)0x14, temperature);
        eeprom_busy_wait();
        eeprom_write_word((uint16_t *)0x16, (ground_alt/100));
    #endif
        groundstartDone = true;
        debug_handler(6);
    void startup_air(void)
      uint16_t temp=0;
        eeprom_busy_wait();
        temp = eeprom_read_word((uint16_t *)    (y*2+2));
        AN_OFFSET[y] = temp/100.f+200.f;
        eeprom_busy_wait();
        press_gnd = eeprom_read_dword((uint32_t *) 0x10);
        eeprom_busy_wait();
        temperature = eeprom_read_word((uint16_t *) 0x14);
        eeprom_busy_wait();
        ground_alt = eeprom_read_word((uint16_t *) 0x16);
        ground_alt *= 100;
    #endif
          Serial.println("***Air Start complete");
    void debug_print(char string[])
      #if PRINT_DEBUG != 0
      Serial.print("???");
      Serial.print(string);
      #endif
    void debug_handler(byte message)
      static unsigned long BAD_Checksum=0;
        switch(message)
            case 0:
            Serial.print("???Software Version ");
            break;
            case 1:
            Serial.println("???Air Start!***");
            break;
            case 2:
            Serial.println("???Ground Start!***");
            break;
            case 3:
            Serial.println("???Enabling Magneto...***");
            break;
            case 4:
            Serial.println("???Enabling Pressure Altitude...***");
            break;
            case 5:
            Serial.println("???Air Start complete");
            break;
            case 6:
            Serial.println("???Ground Start complete");
            break;
            case 10:
            BAD_Checksum++;
            Serial.print("???GPS Bad Checksum: ");
            Serial.print(BAD_Checksum);
            Serial.println("...***");
            break;
            default:
            Serial.println("???Invalid debug ID...***");
            break;
        #endif
    EEPROM memory map
    0 0x00        Unused
    1 0x01         ..
    2 0x02         AN_OFFSET[0]
    3 0x03         ..
    4 0x04         AN_OFFSET[1]
    5 0x05         ..
    6 0x06         AN_OFFSET[2]
    7 0x07         ..
    8 0x08         AN_OFFSET[3]
    9 0x09         ..
    10 0x0A        AN_OFFSET[4]
    11 0x0B        ..
    12 0x0C        AN_OFFSET[5]
    13 0x0D        ..
    14 0x0E        Unused
    15 0x0F        ..
    16 0x10        Ground Pressure
    17 0x11        ..
    18 0x12        ..
    19 0x13        ..
    20 0x14        Ground Temp
    21 0x15        ..
    22 0x16        Ground Altitude
    23 0x17        ..
  • My problem is that my custom autopilot is taking the serial string (not the fast serial). I looked into the code, and the fast serial string was being output with every run through the main loop. In the code I changed two things: first of all, I have it outputing the the gps data (even if it's not new) every time. My gps is set to 5hz, so I'll look into the implications of this. Secondly, I put the serial output function call into the main loop. This really increased the rate at which I was receiving data! For my application, it's perfect. I am getting the serial string (which I also modified btw, taking out all the RLL: & PCH: print statements, so I get a smaller string like this:
    !12.32,-4.25,112.84,243, (TOW, Lat, Lon, ect.)
    I'm not sure if removing those was absolutely necessary, but I didn't want the loop to be dragged  down by calling a bunch of unnecessary serial print statements.
    If anyone wants the code, I'll either post it here or PM it to you. (I don't know if It's possible but I'll try)
    Thanks for the ideas guys! And hopefully you'll find some uses for a faster serial output on the ArduIMU. :)
  • Hi Scotty,
    at what Hz does the ArduIMU provide data as a default?
