Faulty pressure sensor on the Ardu Pilot Mega IMU
I've made some flights today with my hexa (2.0.46 firmware version).
The problem is that even if i the flight was sometimes at 10-15m on the kmz file/log the altitude reported by the baro was max 1-2 m.
 I don't have a sonar installed.
How can i check to see if the baro is dead ? It can be replaced ?
I've attached the log and kmz file. I will upload a video soon.
Thanks for your oppinions / help.
2011-10-04 07-31 4.log
2011-10-04 07-31 4.kmz
  • Hi Alex,
    The values should change for the tests that you've tried. You can also check to see if the ADC chip is working correctly: try running the ADC test in CLI mode and see if the gyro values are normal (around 1600)? If the gyro values are incorrect (i.e. 0 or 1) then there may be a problem with the ADC chip. If the gyro values are fine, then the pressure sensor is likely the problem.
  • Try to go to test -> altitude in CLI mode via APM Planner terminal for instance and see what it will show you...
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
