feytech mapmaker error fy-21aP gcs
hi folks,
i just got a complete kit x4 from feytech, been able to set it up without worries, quite nice stuff.
i have took the cgs option, but, in order to create autpilot flight, you need to create a map.
this is the procedure:
launch google earth (in full screen mode) on your location
then launch mapmaker
clic on ge mapbox information
then you get a window telling you that google earth should be open first, you clic on yes,
and then i get a run time error (using xp or 7), and then it close....
so i can t do autopilot flight
did one of you experienced same error?
this where you can find the files, you don t need to have the material installed
http://shop.fyetech.com/product_info.php?cPath=&products_id=42
Can you pls try it and tell me if you have same issue?
here is a screenshot of the error using 7 with (run as admin) privilege when launched the prog
thxx for your help!
