figuring out the Antenna Tracker
3691139590?profile=originalNot many people know but we have an piece of open source software for controlling an Antenna Tracker.  It's been built by Tridge (Arduplane lead developer) for use in the outback challenge.
Sadly we have no documentation and, as far as I know, nobody except Tridge has used it.  Still given Tridge's track record on building great software I suspect it works well and if it doesn't, I'm sure we can fix it.  So to not let this piece of code go to waste, I'd like some help from people who are interested to give it a try and help me figure out how it works.
Here's the little that I know:
  • It runs on any of our supported board (APM1, APM2, PX4, Pixhawk, Flymaple and perhaps VRBrain)
  • For APM1/APM2 users building the code is as easy as opening our hacked ArduinoIDE and selecting File > SketchBook > Tools > AntennaTracker and then building in the normal way.  For PX4/Pixhawk, our autobuilder doesn't automatically build a binary but I can provide one if people are interested.
  • It can control a Pan and Tilt gimbal like this or this found on servocity.com.
  • It may or may not require a GPS
  • It must somehow receive vehicle position updates from the ground station which has the telemetry radio that is connected to the vehicle. Maybe through a USB cable.  Tridge probably uses the python ground station, MAVProxy, to passthrough the vehicle position data to the AT but perhaps we can get MichaelO to build out a similar feature in Mission Planner.
  • I imagine this antenna tracker could also be used to keep a camera focused on the vehicle which might be good for easing the burden on creating videos of our vehicles.
So if you want to give it a try please do and stick any findings, questions or issues below. Alternatively Issues can go into the issues list.
I'll start sticking things into the wiki as they become clear.
                    Hi Tim.  I assume you have made no code changes in your repository.  If you have you will need to stash them with "git stash" BEFORE you run this command.  See in your post it has the line
                    Your branch is ahead of 'origin/master-AVR' by 1264 commits.
                    This means you effectively have master-AVR with all the master changes in it.  So you need to reset back to the head of master-AVR with this command
                    git reset --hard
                    This WILL delete any local changes you have made so make sure you stash first if you have anything.
                    Then go through the make clean, make apm2 again and let us know.
                    Thanks, Grant.
                  • Renamed config.mk file to config-old.mk and tried again with make clean not make clear.  Sorry about that.  The result is the same though.
                    timgold@timgold-VirtualBox:~/ardupilot$ ls
                    AntennaTracker        config-old.mk     modules
                    apm.pdef.xml          CONTRIBUTING.md   Parameters.html
                    APMrover2             COPYING.txt       Parameters.wiki
                    ArduCopter            docs              README.md
                    ArduPlane             Doxyfile.in       reformat.sh
                    binaries              eclipse.cproject  tmp
                    Build.AntennaTracker  eclipse.project   Tools
                    Build.APMrover2       libraries         uncrustify_cpp.cfg
                    Build.ArduCopter      Makefile          uncrustify_headers.cfg
                    Build.ArduPlane       mk                Vagrantfile
                    build_binaries.sh     module.mk
                    timgold@timgold-VirtualBox:~/ardupilot$ cd AntennaTracker/
                    timgold@timgold-VirtualBox:~/ardupilot/AntennaTracker$ git checkout master-AVR
                    M    modules/PX4NuttX
                    Already on 'master-AVR'
                      (use "git push" to publish your local commits)
                    timgold@timgold-VirtualBox:~/ardupilot/AntennaTracker$ git pull --rebase
                    remote: Counting objects: 172, done.
                    remote: Compressing objects: 100% (100/100), done.
                    Receiving objects: 100% (172/172), 118.78 KiB | 21.00 KiB/s, done.
                    remote: Total 172 (delta 134), reused 70 (delta 70), pack-reused 2
                    Resolving deltas: 100% (134/134), completed with 31 local objects.
                    From git://github.com/diydrones/ardupilot
                       2ffabe9..f08a4af  master     -> origin/master
                    Current branch master-AVR is up to date.
                    timgold@timgold-VirtualBox:~/ardupilot/AntennaTracker$ make clean
                    timgold@timgold-VirtualBox:~/ardupilot/AntennaTracker$ make apm2
                    ../mk/targets.mk:13: *** apm2 is deprecated on master branch; use master-AVR.  Stop.
  • I am making some headway on getting things working, but one things has me stumped.  I am using the M8N gps, and have excellent hdop (1.3) and sat count (11) but the antenna tracker is wandering all over the place.  Here is a screenshot from MP.  The antenna tracker is located in the house on the right, about 100 feet away.  I thought perhaps over time it would settle out, but no dice.3702116120?profile=original
    • This is the reason why I implemented a special filter in my custom build. I simply avarage GPS data using only 5% of the most recent position and adding it to 95% of previously calculated position. It is of course only valid if your tracker is not moving around.
      I am still short on free time but these changes will eventually make it into master... Be patient :)
    • m8n is very "touchy" about RF noise, if your tracker is compact and GPS is right next to servos and your RFD900 than I think RF noise is your problem.
      • Good call Artem.  It was definitely RF interference.  I did a very quick test by isolating the m8n gps with some tin foil.  The position accuracy improved immediately.  So I took the time to swap the gps to a old neo-6m I had laying around, and isolated it with some aluminum tape, creating a nice ground plane at the same time.  Accuracy is consistently within about 10 feet now.  Much better.  Thanks for pointing me in the right direction.
      • If it was a rf noise issue, wouldn't the hdop be higher and sat count lower?
        • not necessarily. I find that cheap m8n's are much worse than old lea-6h.  Only a few manufacturers were able to shield/filter unwanted frequencies well enough on m8n and those units are sold for about $90-$100, while performing marginally better than leah-6h  for $50
          • I have a bunch of lea 6 and neo 7 gps's here.  I can try some of them and see if they are any better.
    • Jeff,
      That looks to be about standard -- I'm getting similar results. Since my drone is far relative to the tracker, the GPS noise isn't too big of a deal, but it can be a problem if your vehicle is close to the tracker (worst case will be if it's right over the tracker in which case the tracker will be all over the map). One option is to disconnect the GPS and specify the HOME position of the tracker via APM parameters. Since your tracker won't be moving, then you'll be 100% accurate!
      It would be nice if the code running on the tracker had the ability to significantly average the GPS readings. For most users, the tracker does not move -- so heavy duty averaging should eliminate the GPS noise you're seeing.
