figuring out the Antenna Tracker
3691139590?profile=originalNot many people know but we have an piece of open source software for controlling an Antenna Tracker.  It's been built by Tridge (Arduplane lead developer) for use in the outback challenge.
Sadly we have no documentation and, as far as I know, nobody except Tridge has used it.  Still given Tridge's track record on building great software I suspect it works well and if it doesn't, I'm sure we can fix it.  So to not let this piece of code go to waste, I'd like some help from people who are interested to give it a try and help me figure out how it works.
Here's the little that I know:
  • It runs on any of our supported board (APM1, APM2, PX4, Pixhawk, Flymaple and perhaps VRBrain)
  • For APM1/APM2 users building the code is as easy as opening our hacked ArduinoIDE and selecting File > SketchBook > Tools > AntennaTracker and then building in the normal way.  For PX4/Pixhawk, our autobuilder doesn't automatically build a binary but I can provide one if people are interested.
  • It can control a Pan and Tilt gimbal like this or this found on servocity.com.
  • It may or may not require a GPS
  • It must somehow receive vehicle position updates from the ground station which has the telemetry radio that is connected to the vehicle. Maybe through a USB cable.  Tridge probably uses the python ground station, MAVProxy, to passthrough the vehicle position data to the AT but perhaps we can get MichaelO to build out a similar feature in Mission Planner.
  • I imagine this antenna tracker could also be used to keep a camera focused on the vehicle which might be good for easing the burden on creating videos of our vehicles.
So if you want to give it a try please do and stick any findings, questions or issues below. Alternatively Issues can go into the issues list.
I'll start sticking things into the wiki as they become clear.
    • This is a good idea - most "off the shelf" antenna trackers use either teletext data or audio channel data. It would be nice if our firmware could work this way.
      Provided that you supply a proper hardware (TX modem and RX modem) the implementation into AT firmware should be easy if not trivial (audio RX can output a fake mavlink frame into AT)
    • this is better to use data feed inside RC link like in UltimateLRS and it's works really well.
      http://www.itluxembourg.lu/site/ultimate-lrs-wiring-diagram/
      and dedicated forum here :
      http://www.rcgroups.com/forums/showthread.php?t=2037442
      Ultimate LRS wiring diagram
      • MR60
        UltimateLRS, This what I use to get long range telemetry on a budget and it works perfect with orange TX modules (default antenna need to be replaced by more reliable ones, I use diy dipoles). I recommend it too!
        • try gitsly brunch of openlrs NG, has 57k mavlink support and works on all hardware including dtf/uhf and Flytron (HK Orange)
          https://github.com/gitsly/openLRSng
          gitsly/openLRSng
          openLRSng (with extended telemetry support). Contribute to gitsly/openLRSng development by creating an account on GitHub.
      • It doesn't support quality hardware like DTF UHF, I've had enough with HK orange crap. (RF dirty when works, two modules I used  were making my sat count on 3DR lea6h drop 2-3 satellites worse than a lawmate 1w vtx (verified 978mw) on 1200mhz within 7" from GPS) For comparison 1w DTFUHF Rx (870mw) has 0 effect on the same GPS at the same place with the same antenna and every single of the total 3 Tx units and 10+ Rx worked right away without issues.
        Ideally I would just write a lua scrip for taranis to control two servos :)  based on telemetry from FRSKY telemetry of openlrsng which I get natively from pixhawk.
        It's a shame that flipflap doesn't want to comply with GNU license, otherwise someone would've ported it to DTF UHF hardware (order of magnitude better than HK orange)
        • MR60
          It does support DTF UHF in version 2; Orange TX 1 watt modules were shown cleaner in their RF emissions than some much more expensive brands, see rcmodelreviews ad flip flap own web site; these modules emit at 400mW when fed with 3,3V and closer to one watt when fed with 6V. And finally flipflap complies fully with GNU and released his source code.
          • ok, clarification: DTFUHF stuff is neither supported nor is going to be in the near future.
            http://www.rcgroups.com/forums/showpost.php?p=33030709&postcoun...
            and as far as I know flipflap never disclosed his source code, sharing only hex files so he doesn't comply with the GNU license while undoubtedly using a ton of arduino and original openlrs (flytron) libraries.
            https://github.com/tadam777/Projects/tree/Ultimate-LRS/Ultimate-LRS
            I't been a long time since I've been looking for this code.
            RC Groups - View Single Post - Ultimate LRS: Hassle-Free - Full Mavlink - 16 Channels. Fly More.
          • Well than, as soon as version 2 goes public I'll try it out.
            regarding HK Orange. its notoriously poor QC might be an issue with mine, but nothing beats DTF UHF in harmonics suppression and quality build (in the price range). Moreover, my DTFUHF gear is almost 2 years old and still works as new, I  had 2 HK 1w units which output only 400mw (why they say it is 1w???) and would still effectively kill my GPS reception. To make an orange 1w module to output in 700-800mw range one needs to power the rfm module with 5-5.5v effectively shortening its life span multi-fold.
            I still wonder why rmrc never tested dtfuhf gear especially since HK never been known for good QC?
            DTF UHF is being sold in USA by store with exceptional CS, such multirotorsuperstore.com and multirotormania.com
            Even if I'll ever get a dud unit I know I will get a replacement sent the next day I contact them.
            p.s. I  wouldn't really like putting a 1w Tx unit on a tracker next to my video RX, if anything I would put it at least a meter or two away.
            Registrant WHOIS contact information verification | Namecheap.com
  • This reply was deleted.
    • I flew/drove circles around my tracker and it followed all the time. Both simulated and real vehicles.
