figuring out the Antenna Tracker
3691139590?profile=originalNot many people know but we have an piece of open source software for controlling an Antenna Tracker.  It's been built by Tridge (Arduplane lead developer) for use in the outback challenge.
Sadly we have no documentation and, as far as I know, nobody except Tridge has used it.  Still given Tridge's track record on building great software I suspect it works well and if it doesn't, I'm sure we can fix it.  So to not let this piece of code go to waste, I'd like some help from people who are interested to give it a try and help me figure out how it works.
Here's the little that I know:
  • It runs on any of our supported board (APM1, APM2, PX4, Pixhawk, Flymaple and perhaps VRBrain)
  • For APM1/APM2 users building the code is as easy as opening our hacked ArduinoIDE and selecting File > SketchBook > Tools > AntennaTracker and then building in the normal way.  For PX4/Pixhawk, our autobuilder doesn't automatically build a binary but I can provide one if people are interested.
  • It can control a Pan and Tilt gimbal like this or this found on servocity.com.
  • It may or may not require a GPS
  • It must somehow receive vehicle position updates from the ground station which has the telemetry radio that is connected to the vehicle. Maybe through a USB cable.  Tridge probably uses the python ground station, MAVProxy, to passthrough the vehicle position data to the AT but perhaps we can get MichaelO to build out a similar feature in Mission Planner.
  • I imagine this antenna tracker could also be used to keep a camera focused on the vehicle which might be good for easing the burden on creating videos of our vehicles.
So if you want to give it a try please do and stick any findings, questions or issues below. Alternatively Issues can go into the issues list.
I'll start sticking things into the wiki as they become clear.
    • I'm using CR servos, but if I setup CR in the extended tuning, it oscillates like crazy. So I use CR, but choose position.
      • It is not supposed to work like that at all. Position servos may work with CR code, not the other way around. This is why you get strange oscillations and go beyond mechanical limits. It will be extremely difficult to tune it properly, thus I highly recommend using CR code with CR servos. Can you describe your problems with CR code?
        • I changed back to position servo on pitch, and all works well now, other than that the yaw starts to rotate (and not always) when connection is lost. It seems my observation earlier that it rotates in the direction it was moving when the connection got lost is correct.
          Using the CR mode before, my problem was that it oscillated in pitch heavily, unstopable. No matter which value I changed form the tuning settings, it just kept going on and on. That's why I think an autotune function would be a great feature.
          Funny enough, CR servo on pitch worked very well with position mode, other than going over the mechanical limit and burning the servo.
          Eventually, I would like to use a heavy dish antenna to increase the range and I think that will only possible using a gear and CR mode.
    • This is odd. Are you using CR servos or position servos? The tracker should enter scan mode automatically and it possibly does that ignoring some limits (thus burning servos). This can happen if you set your RCx_MIN and MAX incorrectly on position servos. With CR servos firmware only relies on AHRS but it still doesn't explain why it moves past limits. I don't remember now but maybe the version you used is meant for my tracker that operated without any limits in every axis - not many people use CR servos and I was the only one to have CR servo on pitch axis.
      • I have disconnected the pitch servo as I'm flying long distances and put my pitch manually to almost level.
        But I noticed yaw is doing the same. When connection lost, he sometimes (not always) turns randomly.
        I may have seen this: he moves bit by bit, following the plane. The connection gets lost when he just move d. As a result, he keeps on moving in the direction he was moving just as the connection got lost.
        Not 100% sure, but it seems to be that way.
  • Files were too big, here they are again
  • Here are some log files
  • 3702185605?profile=originalI have modified a MFD antenna tracker according the pictures. I use 2 360 degrees servos for both pitch and yaw.
    Yaw does have a slipring, so can rotate free. Pitch is limited to minus 15 (down) to plus 90 (up). I have mounted the pixhawk on the boom and I use Jakub's software as I use this tracker in a more or less professional environment and I need it to work.
    So far, so good.
    But I have encountered the following problems:
    1) When the tracker looses connection with the target, it starts to randomly move. For yaw, no problem, but for pitch, I have now burned 2 servos because they come to the mechanical end stop and still want to move further
    2) If I select 360 degrees servos in the setup, the whole thing starts to oscillate like crazy
    3) PID settings are very hard to figure out
    To add a bit of hope for those struggling to get the tracker working.  This is a video from Philip Rowse who got his tracker working for the first time over the weekend.
    • gee you lucky been trying for 6 months  still no go
