Not many people know but we have an piece of open source software for controlling an Antenna Tracker. It's been built by Tridge (Arduplane lead developer) for use in the outback challenge.
Sadly we have no documentation and, as far as I know, nobody except Tridge has used it. Still given Tridge's track record on building great software I suspect it works well and if it doesn't, I'm sure we can fix it. So to not let this piece of code go to waste, I'd like some help from people who are interested to give it a try and help me figure out how it works.
Here's the little that I know:
- It runs on any of our supported board (APM1, APM2, PX4, Pixhawk, Flymaple and perhaps VRBrain)
- For APM1/APM2 users building the code is as easy as opening our hacked ArduinoIDE and selecting File > SketchBook > Tools > AntennaTracker and then building in the normal way. For PX4/Pixhawk, our autobuilder doesn't automatically build a binary but I can provide one if people are interested.
- It can control a Pan and Tilt gimbal like this or this found on servocity.com.
- It may or may not require a GPS
- It must somehow receive vehicle position updates from the ground station which has the telemetry radio that is connected to the vehicle. Maybe through a USB cable. Tridge probably uses the python ground station, MAVProxy, to passthrough the vehicle position data to the AT but perhaps we can get MichaelO to build out a similar feature in Mission Planner.
- I imagine this antenna tracker could also be used to keep a camera focused on the vehicle which might be good for easing the burden on creating videos of our vehicles.
So if you want to give it a try please do and stick any findings, questions or issues below. Alternatively Issues can go into the issues list.
I'll start sticking things into the wiki as they become clear.
Andre,
The fix for Telem2 isn't in master yet. It's only sitting in my febe-gimbal5 branch. I'll merge it to master later this week and push out AT0.3 as an official release before the weekend.
But in Missionplanner I can load AT V0.3. What are the changes of these V0.3?
Andre,
Ah right. I'd forgotten that for antenna tracker goes straight out to the mission planner with no release management! We will fix that. Ok, so now that 0.3 has snuck out, we will name the version with the telem2 fixes "0.4".
He put the mavlink routing stuff in, but the telem2 fix isn't in yet.
I am stuck ...
one question at the side - if I use a 3DR uBlox GPS with compass, do I connect the compass to the Pixhawk? Or do I only use the onboard compass of the Pixhawk?
If I have to use the compass in the GPS unit - where do I mount the GPS unit? If it is mounted on the tilt axis, then the GPS will have a bad signal if the tracker points upwards;
if I mount it on the frame of the tracker, then the 3axis compass of the GPS unit will not tilt - thereby the values will be different than the values of the 3axis onboard compass of the Pixhawk ... (I hope you understand what I mean).
I have built the tracker, the tracker (Pixhawk) is connected via USB to my computer;
the tracker is connected via telemetry to my copter.
I get a green blinking light on my Pixhawk (on the tracker) - but nothing else happens.
If I press the safety switch the light keeps on blinking green - no movement of the tracker.
@Felix,
I use the pixhawk's internal compass on my setup. It's fine to use an external compass (like the one in the 3DR GPS+compass module) but this compass must move with the pixhawk so it needs to be mounted on the same moving platform that the pixhawk is on. With my particular setup it's difficult to mount it like that and still have the GPS pointing upwards so I've left the compass wire (the 4-wire I2C line) disconnected.
The green blinking light means that it's got it's own position. Once it knows the position of the vehicle it will go solid green.
@ Randy - thanks for the information.
My vehicle (3DR IRIS+) had GPS lock and was armed - but the tracker just kept on blinking green.
On the mission planner I could see the position of both, the IRIS and the antenna tracker.
Putting the tracker into auto mode or scan mode didn't change anything. Only in manual mode it drives until it reaches the maximum position.
Felix,
On the MP, if you select Ctrl-X and then select the copter from the drop-down, do you see the attitude in the HUD change as you tilt the vehicle? I'll bet you don't. This means that the position and attitude is likely not updating. In this situation if you disconnect with the mission planner and then connect again it should work. The last thing to check is on the MP's Config/Tuning screen on the "Planner" screen there's a row called "Telemetry" and it has 5 drop-downs named "Attitud", "Positio", etc. Make sure those are all non-zero. set them to a number between "2" and "5".
@ Randy,
you are right - the altitude and vertical speed does not change in the HUD.
Everything else works (armed, disarmed, ground speed, yaw, flight mode etc.).
Disconnecting and re-connecting doesn't change the situation.
The MP telemetry rates are:
altitude 10 / position 3 / mode, status 2 / RC 2 / sensor 2
If I change the altitude to 5 (you wrote the values should be between 2 and 5) it stays, until I re-connect the MP - then the alt value is back on 10.
If I check the HUD, it shows for the tracker and the IRIS a GPS 3D fix.
The HUD of the tracker displays "disarmed". I get a steady red light on my safety switch if I press it; the "arm" button in MP doesn't change the "disarmed" message on the HUD.
Randy mentioned something about pushing v0.3 but nothing so far. Be nice if Mission Planner could integrate a setup wizard for the Antenna Track much the way they have for the air frames.
Still not excited the Telm2 is still not working for me. Has anyone been able to get that working?
95
96
97
98
99
of 104 Next
