Not many people know but we have an piece of open source software for controlling an Antenna Tracker. It's been built by Tridge (Arduplane lead developer) for use in the outback challenge.
Sadly we have no documentation and, as far as I know, nobody except Tridge has used it. Still given Tridge's track record on building great software I suspect it works well and if it doesn't, I'm sure we can fix it. So to not let this piece of code go to waste, I'd like some help from people who are interested to give it a try and help me figure out how it works.
Here's the little that I know:
- It runs on any of our supported board (APM1, APM2, PX4, Pixhawk, Flymaple and perhaps VRBrain)
- For APM1/APM2 users building the code is as easy as opening our hacked ArduinoIDE and selecting File > SketchBook > Tools > AntennaTracker and then building in the normal way. For PX4/Pixhawk, our autobuilder doesn't automatically build a binary but I can provide one if people are interested.
- It can control a Pan and Tilt gimbal like this or this found on servocity.com.
- It may or may not require a GPS
- It must somehow receive vehicle position updates from the ground station which has the telemetry radio that is connected to the vehicle. Maybe through a USB cable. Tridge probably uses the python ground station, MAVProxy, to passthrough the vehicle position data to the AT but perhaps we can get MichaelO to build out a similar feature in Mission Planner.
- I imagine this antenna tracker could also be used to keep a camera focused on the vehicle which might be good for easing the burden on creating videos of our vehicles.
So if you want to give it a try please do and stick any findings, questions or issues below. Alternatively Issues can go into the issues list.
I'll start sticking things into the wiki as they become clear.
Paul,
I've been thinking of adding support for the do-set-roi command. So that you could click on a point on the map and it would just always point at that. I can't promise when I'll do that but i've been thinking about it for a while.
Paul,
I've modified v0.5 of the tracker to do exactly what you want, since we need to point to a specific GPS coordinate. All I did was to disable the auto-scan mode on loss of signal, and I just feed the tracker GPS Mavlink messages to get it to point. I am happy to attach the source code if you'd like it.
-Ted
Here's the changed file. You'll have to recompile the software according to these instructions:
http://dev.ardupilot.com/wiki/building-the-code-onlinux/
Also, I'm not sure I fully grok your setup, but the tracker needs MAVLINK GPS messages to tell it where to point TO. For my setup, I wrote some software to take a GPS location and convert it into a MAVLINK IGPS message and send it to the tracker. The tracker thinks it's getting a vehicle GPS message and points in that direction. If you are moving the tracker, it will stay locked on the target GPS location.
Good Luck,
Ted
tracking.pde
for some reason the compass is slowly turning in mission planner. did several calibrations but it wont stop. it's like the second hand on a clock. not sure why this started. nothing changed from when i used it months ago...except firmware. any ideas
also, the pitch is stuck at 45 degress again. i thought this problem was fixed. please help. over a year and still i cant get it to work,
Hi All
Going around in circles a bit, I decided to drop my bid to get AntennaTracker working as part of a multinode network and focus on trying to just get it working first.
I've read and tried all the suggestions on all 48 pages of this thread but not having a lot of luck.
I can get it connected via USB and then a radio link to my quad from the AT and both are appearing in Antenna Tracker.
However the AT just doesn't seem to behave at all.
Pitch seems ok. but I can't get YAW to track.
I have an eagle eyes tracker and have set it to 180 degrees precisely. The upper and lower limit of the servos go to 180 degrees.
I can see the orange line pointing in the correct direction but the red line is way off and the yaw servo doesn't move to try and bring it into line.
But then if I tile the AT, it suddenly starts moving.
So something is working, but yaw just seems eratic and not at all close to what it should be doing,
I have tried
sometimes it looks like its about to work right and then it stops mid pan or overshoots and then ends up pointing in some weird direction.
I can see the red line in MP is showing correctly the direction the AT is pointing but its not trying to move the servo to move to the orange line (which is also correct).
I can't seem to figure out why it will not track.
I have standard servos.
APM 2.5
internal compass, external GPS.
Any suggestions on what might be up would be great, happy to post a video or any logs if that would help.
I really want to get this going so that I can figure out the multinode networking and then post instructions on how to set that up.
describe your tracker (servo type and configuration) and post your PID settings and FW version
eagle eyes tracker
currently using Futaba S3000 position servo's but I have ordered some CR servos to see if that makes it easier.
Have tried the default pids and suggested Pids here.
P 0.2
I 0.1
D 0
IMAX 4000
slew 2
51
52
53
54
55
of 104 Next
