Finding Flight Modes from Datalogs
I would like to be able to find out at which times I switched from one flight mode from the other using the 'log browse' within the Mission Planner.
For example, I start off in stabilize mode then switch to alt hold mode once off the ground.  I would like to know the time I switched into alt hold mode to compare it to my motor outputs.
I know that ArduCopter should be able to log flight modes- but I want to know if it's something that I'm overlooking or is it something software-wise?
ALSO NOTE: When I open the CLI and go logs>>enable mode,  mode does not seem to show up. This is the output:
Log] enable mode
logs enabled:  ATTITUDE_MED GPS PM CTUN NTUN CMD
Is the software not taking my command to enable mode logging or does it just not parrot back mode for some reason?
