Flight modes
The Ardupilot allows you to have multiple flight modes of which I would actually only need 2 and downsizing has already been discussed but downsizing irrelevant code is not what I want/need.
Could I have two sets of autopilot code one setup for fast servo control, the other setup for slow servo control? (Space permitting or if not remove another mode for space)
Could I add altitude based servo variables? the higher she goes the slower the servos react
I will be using a glider first off (because I dont care if it breaks) so motor control is not needed. Is there a variable for this or do I delete/adjust a section of code
  • I would also like to increase my mode options. to use the mixing option to get 6 modes, will this require reprogramming of the Atiny?
    Thanks for all your help
  • Does anyone know if it is possible to add more than three modes to the control modes? I have a proportional dial on channel 7 on my hitec eclipse 7 and I would love to be able to do manual, stabilize, waypoints and RTL on the same flight.
    I do this when testing....
    void read_control_switch(){
    byte switchPosition = readSwitch();
    if (oldSwitchPosition != switchPosition){
    switch(switchPosition)
    case 1: //
    set_mode(POSITION_1);
    break;
    case 2: //
    set_mode(POSITION_2);
    // set a variable here such as a PID value
    break;
    case 3: //
    set_mode(POSITION_3);
    break;
    oldSwitchPosition = switchPosition;
    // reset navigation integrators
    reset_I();
    You can certainly implement this in your code. Look at the roll slew rate limiter. If you set up a similar pitch slew rate limiter and then set up modes which change the limiter parameters that would do what you want.
    If you are not using a motor then use the airspeed sensor. Elevator will be based on airspeed hold. You can just ignore the throttle parameters.
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
