After one year and a lot of flights without crashing, my Flip FPV suddenly dropped from 30m after motors stopped.
I was flying FPV. I noticed minimosd rebooted and maybe one second after, quad just fell like a rock.
Nothing changed recently except that I unplugged my receiver to reinstall it in a cleaner way and plugged all wires back.
So, the flight was:
- arming
- take-off in stabilize
- loiter at maybe 10-15 meters.
- put fpv goggles on and increased altitude (still in loiter).
- then moved fwd (loiter mode).
- after a short distance and about 30m high... drop.
Log and tLog attached.
Flip FPV in pretty bad shape. Have to change all 3 deck plates and some standoffs.
THANKS for help ;o)
2015-07-22 12-39-00.log
2015-07-22 14-11-26.tlog
  • Multiple motor loss on a Heli?
    • Quadcopter reboot in flight: 4 motors stopped abruptly (disarmed).
  • Just found this:
    http://diydrones.com/forum/topics/repeated-mid-air-apm-reboot-only-...
    Same scenario as mine: everything was fine before as shown in the log, flying close to the weather radar s-band, sudden reboot and crash. If I set aside the damaged parts by the crash, everything works fine, no loose connection found.
    Weather radar maybe the enemy!
  • Checked the log again and power parameters just stopped suddenly in flight. Let say it was a power loss, I still don't know how this could have happened.
    The power module is a brand new 3DR with excellent voltage signal and I checked connections, everything seem ok.
    The only things powered by the APM are the telemetry module and the gps/compass module.
    The minimosd rebooted just before the crash (consequence of an APM reboot???).
    The receiver is a FrSky V8FRII and this is the only thing I disconnected/reconnected before this flight. It worked fine for many flights before. It is powered on its own by an ESC, no power line to or from the APM. So I don't see why the recent work on it could make a reboot of the APM and /or loss of power.
    This day I was flying with 2 other people, but this is not the first time. However we were in fields near a weather station with a Doppler radar and probably other communication systems hidden inside. I would have understood strange behavior in case of interferences but a sudden power cut?!?
    Video of the crash from the onboard camera + another one captured by my friend's Phantom (quite funny) to follow...
    • that little thiny wires connections that plug the PM to the board sometimes fails, check them or try to change if you don't discover another thing.
      • I just changed the PM recently because of low Vcc with my previous chinese clone PM. The 3DR provides a clean signal. However I will investigate on this.
  • I can't give you a why, but the log looks corrupted as just before the end, the time stamps go backward in time by a couple of minutes (~2m 23s).  This might be an artifact of sudden power failure (say short or power disconnect, which wouldn't have been logged), but I really don't know.  Up to that point it looks good to me.
    • Thanks for your inputs. I looked into the logs again and cannot see where the issue came from. I plugged the battery back, played with electrical connections, armed and everything seems ok. However it is still covered with mud so I did not run motors.
      I also recently changed the power module from a chinese clone to a real 3DR and it solved low Vcc issues.
      I have no choice but to rebuild it since all plates are cracked in several places.
