flying 2.0.19
Curious as I am I loaded the code with the latest MP. All went well but when I armed the motors and fly , only two motors started. And the quad kept turning to the right without liftoff.
Then I loaded 2.0.19 with arduino, and did CLI setup. I couldn't arm the motors. When I used the setup of the planner it worked. Also used Xbee with 115200 and works great.
First flight was very wobbly so lowered P to 0.2  I to 0,02 and D to 0.09 in stable.
I was able to fly more stable. But the problem I keep having is when I bank left or right the yaw changes without stick input.
This is something I had since using  2.0.2.
Could this be a PID setting?
  • Just switched to version 20 and yaw problem seems gone!!!!!!
    Did a reset and loaded everything with arduino and also did setup with CLI.
    Then lowered PID in stable and the quad flies very stable. Some little more tuning needed. Its allmost like the ardupirateNG code.
    Mavlink works also great. Just one issue with altitude. This doesn't show very correct. When I'm 2 meters of the ground it says 10m in tge GCS. At 4 m the GCS says about 20m. Or is this an pid setting.
    Didn't try alt hold yet ;-)
  • I haven't tried with mag enabled. But in the previous versions it did'nt work neither. Nevertheless I will give it a shot this evening.
    When I fly slow the yaw stays fix without any problem. and doesn't change. Only when I bank hard left or right and stop the quad by compensating a bit in the other direction it starts turning a bit.
    Its like it wants to compensate. Its very difficult to orientate immediately after the turn.
    Furthermore I would like to add the the pid tuning goes rather well. Its going in the right direction. The development that is ;-)
    Noticed something very stranged... 2.0.19 with CLI offsets 'calibrated' (I think it messed up more than anything else...) I go to the planner sensor view screen and my YAW starts around 90 and slowly moves to 125... then when I move the quad on it's axis the YAW change but when I stop it slowly moves back to 125 (it's "original" location) even if the quad is 90 degree from my starting point...
    I am afraid to fly this like that... but maybe this could help finding the YAW issue.
    BTW, is there an easy way to undo the offsets calibration?
  • I do not know if you have installed a Compass, but my .19 would rotate back and forth somewhat during turns.  This was resolved with a compass, yaw became much tighter.  These were with the default PID's.
    We're flew 2.0.19 and the next version 2.0.20 today, in all modes, and it was absolutely flawless. GPS hold, alt hold, waypoints, simple mode, etc. Everything was rock solid. Jason even did flips!
    He'll probably commit the latest code to the SVN tonight, but I think we're very close to coming out of beta. Jason is tweaking a few setup processes to make it easier to use, and the Mission Planner is being updated accordingly. But based on a couple quads being put through the paces today, I think we've got the most solid ArduCopter code ever.
    Just look how relaxed Jason was watching it! It's staying within a 5m box in 15-20mph winds!
