We're trying to use a panda-board as a mediator between the flight controller and the mission planner. Where we send the bytes read on the serial port to a TCP server running on a linux machine, and the mission planner connects to this server.
But, the problem is that it fails in the connection, and outputs an exception. Has anyone tried forwarding mavlink packets?
  • hello,
    I try to make a bridge between my flight controller using megapirate ng and an android phone with the ioio board for android.
    I have a communication in uart between the two board and I would like tranfer mavlink packet from uart to IP (3G).
    Do you have code or tricks to implements forwarding mavlink packets ?
    Congratulations,
  • Hi,
    I'm doing some thing similar, but with a Beagleboard. I was hoping to use UDP instead of TCP over the Wifi link between the Beagleboard (onboard the copter) and the ground station.
    Any chance I could get a look at your forwarding code?
    i need more information.
    so long as you have 2 way comms, it will work.
