Hi
I´m just finishing my build of this Giant X8 and being a Pixhawk fan the choice of autopilot was easy...
I made a search for D-130 X8 on the net but but didn´t find anything about anyone flying this beast with pixhawk...
I´m a litte bit nervous doing my maiden flight with this 9 000 $ rig. I need some advice...
My setup is
D-130 with U-8 Kv 170 motors on 6s 7200g
Foxtech supreme 2880 (very light 28" props for faster spinup).
2x 6s 16000Mah lipos 1920g each
Align G3 gimbal 1200g plus Panasonic GH4 camera with leica objective 800g
So total TOW will be around 13Kg
My questions??
1. Will it fly decent with default PID settings?
2. Any recommendations for Stab P and Rate P to start with?
3. Would you recommend to make autotune flight with this low Kv motors (sync issue...)?
Tried to run autotune on this beast but it ended up with extremely hoígh values...
Stab P 8,3
Rate P 0,350 I 0,350 D 0,0200
Totally un-flyable values (not able to takeoff)
Made manual tuning instead and it´s now very stable and yet responsive.
Also mounted a second GPS Ublox-N8M With compass
The Neo-8 Recieved twice as many satellites as the Neo-7...!!
The loiter was noticeably more solid and the cold-start was much faster.
Justice gimbal and camera is controlled by a second radio TX
I think that the Pxhawk setup is really easy this days with the wizard and autotune.
The front led:s from e-bay are controlled by rc switch and the blinking ones on the arms are from goodluckbuy and can be controlled by switch but i decided to have them on default blinking
Tuned manually today and it fells very stable now yet very resposive impressive with this big props...
Tested 20 min of rock solid loiter today. Started to tune gimbal and it is almost perfect now only a little small twitches in pitch. Will post video after fine tuning is done.
Pixhawk is fed from 2 different 6s bec:s one to the 6 pin power port and second one feeding output rail.
For V A telemetry I have an Attopilot 180A also connected to the 6 pin power port
Will run autotune nextflight just to see if it gets any better than it allready is.
I have a lot of pictures from my build here http://www.rcgroups.com/forums/showthread.php?t=2213490&page=32
Just made maiden flight.. :)
Tested with default PID:s the first flight.
No problems at all. I will have to increase Stab P and Rate P because it was a little bit slow to react.
Posting a video from todays first flight.
I LOVE THE PIXHAWK <3
http://youtu.be/UXRyKAbkRhI
Thanks for answer Justice
Sounds confident that the kraken flew on default pid. But with 28" props i thought maybe the motors needs more power to spin up fast enough to correct..?
Yes I have armed and spun up all motors without props and (after corrections) they are all spinning the right way and connected to the correct ESC number.
Also checked that all the front motors increased rpm when elevator pulled back etc.... in all directions.
Maybe just give it a try :)
