FPV Camera control options for Spectrum?
Hi Im wondering is anyone out there could offer me some help. I have a DX8 Spectrum Remote for my FPV setup and I have built a dome camera set up so full pan and 45 degree downward tilt. Now I want to know if I can either use one of the Aux switches or Mix switch to turn the left or right stick inflight into camera control or how can I add on a third stick for pan tilt? Thanks for any advice.
  • Do you want to mix pan tilt with roll pitch or give up roll pitch for pan tilt? I'd suggest the first if you really want to use the right stick as I'm not sure I would be comfortable not having access to main flight controls just in case something happens. If you want dedicated pan tilt why not set it up so the knob controls the movement and a switch selects pan or tilt?
