Freefly Movi M5 with Taranis X9D+ & X8R?
Can anyone tell me if it is possible to control my Movi M5 gimbal using my Taranis X9D+ transmitter and X8R receiver?
The Taranis X9D+ is not on the list of controllers recommended by Freefly for the Movi M5, but then I see other gadgets which can control the Movi M5 (which can use sBus or PWM) so I am thinking it is possible, but unsure.  If so, should I use PWM or sBus?
If it's not possible to use the FrSky protocols, I also have a JP4in1 module which can output DSMX protocol, and be used simultaneously with the FrSky protocol trhought the X9d+. I'd rather not use it, but if it's the ONLY way.. Which receiver do you recommend?
Aug 25
