  • It depends on how you use the boat.... If you don't spend days and days on the hook then don't worry about the hours on the generator. It also depends on the weather.... I m all for saving a few bucks but it means sweating because you're not running the AC,l then it s not fun. Diesel gensets are meant to be run and run and run.. And can easily run over 10k hours
    That said, if you spend a lot of time on the hook especially in winter when you may not need the AC, then yes running off the batteries can save money, hours and also bring you some nice quiet time. In some case adding an inverter and a few extra batteries to power the fridge, etc... Will pay for itself in a few months
    Solar Panel Compatible with Blink XT XT2 Outdoor Indoor Security Camera, Waterproof Power Continuou…
    The Blink XT XT2 is a unique designed waterproof solar panel that power your outdoor camera giving it a 24hours steady power supply. All-round adjust…
  • Higher MTBF than a single engine generator, dual engines is overkill for UAV
Aug 25
