Giant Telemaster Twin Engine
I am an UAS Operations student at UND and this is my current project, not school related.  This is a Giant Telemaster (12ft wingspan) that was built from a kit and flown for a few years.  The previous owner then converted it to a twin but never completed the project.  With so many other projects to finish, he decided to give this to me.  The plan is to put 2 ryobi weed eater engines (fully converted for use on a plane) on the wings and an APM.  With this set up the payload bay will start at the nose of fuselage (which has been stretched for CG purposes) to the aft of the wing.  I estimate a 15-20lbs payload capacity.  This is loosely based of the fact we built a Senior Telemaster with a MicroPilot Autopilot and electric power plant, and it can lift 6lbs for an hour endurance.  I built that aircraft to use for research projects within the university (I work for UND Aerospace flying sUAS). With the small 33cc engines and plenty of room for gas the endurance could easily be setup for over 6hrs.  In order to handle the extra weight and the multi-engine setup there are a few modifications to the air frame.  In addition to the original wing mounting spars there is also an aluminum tube running from one nacelle to the other.  Also the inner part of each wing half has been sheeted with ply to prevent flexing due to the weight of the engines creating torque on the wing.  The struts and landing gear have also been replaced by stronger versions. The tail now has 3 vertical stabilizers and rudders to help in the event of a engine failure.  There is still a lot of work to be done but I am trying to finish it before the first snow.  Thoughts, ideas, suggestions?
3690897835?profile=original
3690897987?profile=original
3690898116?profile=original
3690898132?profile=original
  • It has been a while since my last update but the maiden flight went very well.  The aircraft is very stable and easily handles the extra weight.  It took a considerable amount of time to tune the autopilot but we were successful in fully autonomous navigation.  The next step is to tune the APM2 using the new controllers recently incorporated.  The video from the aircraft works very well but the CMOS sensor in the GoPro HD does not like the vibration.  I have installed soft mounts on the engines which did help.  I am currently looking for a CCD based camera with zoom.  It should better handle the vibration.  The following is a video I created at Trabuco Flyers in southern California: http://vimeo.com/user2763445/giant-telemaster
    3692520998?profile=original
    Nice plane!
    I fly a senior telemaster with APM. One thing I've found very useful is to setup flaperons using a mixer, with flap angle controlled by a knob on the transmitter via channel 5. I've found that really useful during takeoff and landing, and for slow photo flights. The senior telemaster handles flaperons really well, keeping stable even with full flaps, but lowering the stall speed a lot.
    Cheers, Tridge
  • 3692397800?profile=original
    3692398169?profile=original
    3692398206?profile=original
    3692398275?profile=original
  • 3692354491?profile=original
    3692354378?profile=original
    3692354591?profile=original
    3692354393?profile=original
    3692354616?profile=original
    3692354658?profile=original
    3692354708?profile=original
    3692354674?profile=original
  • I would revert back to a single engine. If you have two engines you're twice as likely to have an engine failure, have increased system complexity, weight, and expense.
  • New tail section, inner wing area sheeted with ply, payload bay sheeted with balsa, and servos moved aft in the fuselage to allow for an unobstructed payload bay.
    3692298068?profile=original3692297974?profile=original3692298085?profile=original3692298110?profile=original
