I'm using a tarot 2D and a Hero 3 Black. Everything works pretty well. I had to find a good headspeed that didn't cause a vibration issue. Running 1550 RPM all is jello free.
David R. Boulanger
Sean Whitney > David BoulangerJanuary 26, 2015 at 3:37pm
I am pretty set with my head speed which is right around 1150 RPMs. I need a certain amount of pitch for the weight I am running. Right now I have a vertical bounce in my video from the blades swinging by. I need to figure out the frequency of the AC to figure out what isolators will work with my setup.
I am using a Arris 3-axis gimbal which is really nice.
I had that problem when my camera when it was hard mounted to my frame. Once I put the gimbal on it the problem was solved. I've got a 3 axis gimbal being delivered tomorrow that will hopefully take care of the yaw movement I have not been able to get rid of with PID tuning. I think its my governor tuning that is causing the problem and will continue to play with that.
Here are a few samples of different setups I have on my 700 Trex.
1: Fixed shock mount
2: 2 axis cheap gimbal
3: Tarot 2D Gimbal
https://www.youtube.com/watch?v=LSaFcFgp7TY
https://www.youtube.com/watch?v=g5CfLp3WO7A
UAS, Joe Nall looked good. Gopro? Headspeed? Any neutral density filter used?
David R. Boulanger
No Filter used. Yes GoPro, 1230RPM on the head.
Joe
Sean,
David R. Boulanger
http://www.hobby-wing.com/arris-zhaoyun-3-axis-brushless-gimbal.html
Is it vertical jello or just a sharp vertical movement up and down.
David R. Boulanger
Sharp vertical up and down.
Sean,
David R. Boulanger
Sean, Take a look at the link. Its the best I have been able to produce so far. Not saying its perfect.https://www.youtube.com/watch?v=EP7d3VMJBgs
Hi David
For me, very good!!
What (Align) Heli model is that?
Fred
1
2
of 2 Next
