gps
I am a new quad pilot i have the 3DR quad and APM module i have it flying finally, but now i am stuck trying to figure out all the parameters and tunning.
 First issue i have is when in mission planner it says no gps on the gps module it self nothing lights up or flashes also there are 2 ports on the module for gps and i can't find any info on connecting it i have just purchased the quad so i be leave that it is the newest version of APM i have gone through the search forum still can not resolve the issue any help is very much appreciated.
  • Admin
    Hi Dennis,
    Which module or GPS are you using?  "Nothing lights up". Are you sure you  connect it correctly. did you try connecting it via both ports. what cable are you using to connect to GPS?  Do you have any photo of your setup so that we can see it?
     You see , these are the details that you need to type when you want some help. No one can help if you don't detail.  it would been easy to type answer that you seek then the questions that I need to ask to  understand your  setup. Remember a photo is worth 1000 words.
