Is there a simple way to convert the time stamps in either the ArduGCS ot the Happy Killmore GCS data files into real time? I need to be able to have the actual time so I can tie it to the photos that were taken at that given instance.
Just FYI for any following this thread - the current intent is to change the timestamp handling in APM so that all timestamps can be reported as UNIX time in milliseconds. This work has been started, but has been a low priority and is incomplete. Once that work is done conversion from the timestamp to "real" time and date by a GCS will be straightforward.
Can you explain your question a bit more? The telemetry string includes the time in UTC, which is easy to convert to local time. Where exactly do you want this data saved? Are you using APM to trigger the camera, and you just want to save that action/timestamp in the onboard datalog mission file? If so, that's pretty easy to do.
Any progress on the update yet or has it already been incorporated?
Also, the "datetime" value in the APM Status tab reads blank. Is there any way of turning it on?
